Best place to buy 5' box blade
   / Best place to buy 5' box blade #11
Is there a benefit to having 5 ripper teeth as opposed to 4,, seems like more teeth the better to break up the ground , although I have mostly clay and rock so either way it's gonna be a tough go
In theory, yes, but you must consider the tractor.
The reason we put 4 in the box blades for smaller tractors is to increase the chances of a lightweight tractor to rip through the ground with them.
Travis
   / Best place to buy 5' box blade #12
Backwards. Five teeth have more float than four teeth. Five teeth will more evenly scar ground but four teeth will penetrate tough ground deeper.
(Same way that a Disc Harrow with 9" spacing between pans penetrates deeper than a Disc Harrow with 7" spacing between pans.)
My 6,000th post on T-B-N.
   / Best place to buy 5' box blade #13
I have a Titan box blade (Titan 5' Box Blade Tractor Attachment Category 1 Cat Scarifier Shank Teeth), although I have the six footer, which has been very useful, although at times it needs a sandbag or two on very hard ground. With my FEL on one end and this on the other, I cleaned out the sand and rocks from the "hole" where a neighbor's above-ground pool lived just a couple of weeks ago. They had sand under it, and rocks (two to five inch) all around it. I was able to stay in the hole, drag the rocks to the middle, bucket them out, without needlessly harming any grass.
Edit: mine has six scarifiers, but you can raise up any or all as needed for harder ground.
   / Best place to buy 5' box blade #14
Avoid tractor supply - their implements are glorified popcans. Get a brand name like Land Pride or Farm King.
Yeah I believe the everything attachments box blade is same price or cheaper and I'm sure much better built, so I will probably end up going that route,
   / Best place to buy 5' box blade #16
I have a Bush Hog brand 60" box blade that I love...it is perfectly matched for my B1700...4 scarifiers...
If I was in the market for a box blade the one thing I would look for that is different than what I have...is a design that is favorable to one day converting/modifying it to hydraulic rippers...
Travis
Hello travis are the 60" box blades in stock or is there a wait time on them also, thanks
Dustin
   / Best place to buy 5' box blade #18
Dustin
We have one of these ready to roll. 60" Orange.
Travis
Land Shark 2.1 Compact Box Blade
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2014 PETERBILT 367 (A50854)
2014 PETERBILT 367...
Nissan 5k Forklift (A51039)
Nissan 5k Forklift...
2006 International 4400 LP Crew Cab S/A Heavy Haul Truck Tractor (A49461)
2006 International...
Blue-Jet Liquid Fertilizer Applicator (A51039)
Blue-Jet Liquid...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
