I was looking for a cost effective way to reclaim some old pasture with tons and tons of cedars. The goal is to be able to cut hay off the pasture. Here is a representative shot of the cedars.
After reading everything I could find a tree saw looked like the best option so I picked up this Dougherty Turbo Saw this afternoon.
I asked and the sales guy wasn't sure if it was quick hitch compatible. The I will say that the saw didn't just clip on and go. I will post my findings and you can decide if it is QH compatible or not.
First issue was the top hook couldn't reach the top pin that did appear to be a QH attachment point. A few minutes with the grinder and the hook reached the top pin with room to spare.
Next up is the lower links. Dougherty did provide pins and a Cat1 and Cat2 capability. However the pin they chose wouldn't allow the lower QH hooks to engage. I pulled the large nut off and ground down the threads sothe lower collar would slip on. the lower links hooked up just fine then.
Now the QH easily clipped onto the saw. I hooked up the driveshaft and noticed it looked a bit too short. It had 7" of overlap on the shafts. I don't know if that's enough or not. The directions called for 1/2 the length of the shaft overlap and no less that 1/3 the length of the shaft overlap under any circumstances. The small part of the shaft measured 21" so technically it should work. I didn't feel comfortable risking the shaft coming apart or even wearing out sooner than it should so I removed my QH and hooked it up old school.
![20170912_204940[1].jpg 20170912_204940[1].jpg](https://www.tractorbynet.com/forums/data/attachments/459/459715-1a9ea6a36128037560b1a1b5a2d4d032.jpg)
![20170912_185159[1].jpg 20170912_185159[1].jpg](https://www.tractorbynet.com/forums/data/attachments/459/459752-d34ae680920d1803254fbb3edfb1f826.jpg)
![20170914_121412[1].jpg 20170914_121412[1].jpg](https://www.tractorbynet.com/forums/data/attachments/460/460637-fc25db3196e484b8034ca1190a4e9b52.jpg)
![20170914_125813[1].jpg 20170914_125813[1].jpg](https://www.tractorbynet.com/forums/data/attachments/460/460674-7b3dc4d8d58adb4795fbc1dd8c8bb56b.jpg)
