New tractor equipment and plan
   / New tractor equipment and plan #11
No I haven't logged before but I have been around it my whole life so I know what is involved. I won't break anything, I have been running tractors my whole life, living on a farm and driving them since I was 6 years old, I know the limits. Yard to drop off the logs is only about 5 miles away. I already have a 2500HD diesel truck and a heavy equipment trailer so hauling a couple loads of logs a day or week sure won't wear them out, truck and trailer have done far worse duty. My trees are not huge and where planted in what once was a nice field with good topsoil. I originally was just going to use the tree shear to cut them off and then get a tractor mounted stump grinder to deal with the stumps. If I can push them over standing them the stumps will be easier to remove, just use the grapple to grab them and pile for burning. If the pushing over proves too difficult I will revert to plan A. I am not under the gun by having to make a living doing this and under no time constrains. I will employ my Husky saws as needed but plan to keep that as limited as possible as the goal here is to press forward with the plan and not kill myself and take all the fun out of it :) I had a dozer years back and built my long driveway and dug a pond and considered getting one for this but getting a machine large enough with a cab is expensive and then you are limited to doing just dozer stuff.
Good luck. I use my tractor for its intended purpose and had a great idea once to use my tractor to push over one tree that was in the way of my shop I was fixing to build. I had the loader up, tractor in low range and 4wd and started pushing. Mind you I have cleared lots of land but with the right equipment. I ended up blowing out both curl cylinders on my nice new tractor. I knew better but thought hey it's only one tree.
I get what your saying about running equipment so long. I guess that's why I'm having a hard time why you won't spend 1k a week for the right machine and get a lot more done. You'll make it back on the wood. I cleared my home place by myself. Took me a while because I can't run both pieces of equipment at the same time but when I was done I completed 30k worth of clearing and a 15k house pad and walked away with some money in my pocket still.
Good luck with hauling wood and hope you don't get caught by weights and measures that like to hang out by the mills. You will be overloaded on the truck for sure and most likely the trailer if you load a worthwhile load. I grossed 43k with my old 3/4 ton Cummins in 2007 and was lucky I didn't get stopped. Main truck went down and needed to get the wood off the trailer. How I have a 450 and run legal on weights and even with a 30k trailer, I'm not putting wood on it
Brett
Brett
As stated in the post above I have no plans of damaging my Tractor and if I do I will have insurance. The yard and scales are close and I won't be seeing how much I can fit on each load but rather make more trips. When I had my dozer I did what would have cost me 50-60 grand with it and sold it one one day for the same price I bought it for. I am off work half the time for 28 days each stretch and under no time constraints, so no need to push limits or paying someone to do something I not only can do myself but will enjoy doing. Add to that the feeling of accomplishment once done and that is hard to beat. Stay tuned:)
   / New tractor equipment and plan #13
I think you're going to trash your nice new tractor. My dad is doing work similar to what you describe on his land with a similar cabbed tractor. Total carnage so far is into the 4-digit range - something like 3 or 4 grand. This includes damage to his loader mounts and damage to his air conditioning system. Also, his tractor looks like it has been through a hard life. Dad is 79 years old and has been operating tractors and equipment for basically his entire life, so he's no rookie. Tractors are not made to work in brush with broken limbs, fallen trees, etc.
If I were determined to undertake this project, I would buy or rent a cabbed excavator of 12-14k lbs with a thumb. I'd dig up the bases, push the trees over and stack the stems after cutting the root ball and limbing. Then, I'd use a tractor or even the excavator to load the trailer. In my experience with land clearing and such, an excavator is a great tool to remove trees and move them around. Greater dexterity and the ability to pick and place material.
When you do make a final decision, please post pics and progress information so we all can learn along with you.
agree on the excavator but would rather have a 312-size (around 28k) to push over the trees then use the tractor grapple to carry them after cutting off the root ball which can also be dealt with the grapple. - depending on the # of trees Renting an Excavator for a week and just getting the trees out of the ground would make more sense imo -than using even a 15,000 lb. tractor to push them over,
pine trees over about 12" thick was sometimes work for our 18,000lb jd 550 dozer depending on the roots, but was a breeze with the rented 312 EX-
No disrespect to the OP intended.
but and jmo it comes down to how well these pine trees are rooted and their diameter.
agree on the excavator but would rather have a 312-size or better yet a 320 to push over the trees then use the tractor grapple to carry them after cutting off the root ball which can also be dealt with the grapple. - depending on the # of trees Renting an Excavator for a week and just getting the trees out of the ground would make more sense imo -than using even a 10,000 lb. tractor to push them over,
Renting equipment is not going to happen. Doing so would require I work my *** off, spend a ton of money with nothing to show for it and then still have to do way more manual labor than I have planned. Pine trees and root systems vary greatly where I live. The natural stands and fully mature trees have DEEP tap roots and you basically have to dig a hole the size od a small pond to remove them. These trees however were planted and fast growing shallow roots. Where they are planted used to be a nice field with great topsoil. As I have already mentioned, if they don't push over early easy then I will just use the tree shear and snip them off and buy a stump grinder (another cool toy I want anyway) and grind them out. When I had my little D-21 Komatsu dozer it would much similar trees these size over with easy with way less leverage too. Again if pushing over doesn't work as planned I will just shear them off and deal with the stumps later.
   / New tractor equipment and plan #15
I have very seen so much negativity and doubting Thomas's in my life, lol! Trust me I WILL NOT trash my nice new tractor! The pines are planted in straight rows starting from an open field. I will take my time and always have the tractor working on the clear and open side. This is not going to be a typical logging operation where you are driving in the woods and around hanging limbs and brush. When I do make trails in the woods the same will apply, I won't go charging in but rather switch between the Lane Shark and tree shear as needed and use the bush hog and grapple too. I understand that many may think I am going to wreck my tractor as you do not know me and my level skill at operating machinery. I have many 1000s of hours experience on tractors, dozers BH and other stuff doing just about anything you could imagine and have never broken one. The reason for the cab is to let me work whenever I want and also to force me to go slow and not jepordize myself or the tractor. I plan on the tractor being nice just as nice and shiny once I am done as when I start. I will have insurance also, in the unlikely chance I break a glass of something, and also liability insurance for coverage when I am working for hire on someone else property. Yes I could hire all this done but what fun is that and then I would have no good reason to buy a nice new trator and toys to go with it and be out money to boot. I also have the old trusty 3930 in case I have need of getting in the jungle. I will keep this thread updated as things progress for sure and probably do a Youtube channel with video coverage to boot.
Not sure why you came here asking advice when you already have infallible skills, a perfect plan, and no interest in the advice offered. I do wish you good luck in your efforts, and I hope it goes as planned.
   / New tractor equipment and plan #16
Atleast he has insurance. He keeps mentioning that the soil is great. In soft soil, the tap roots shoots down and goes deep. I understand having 28/28 schedule and wanting to maximize your time and money but I think he is greatly underestimating the amount of work. From someone that has done this over a lot of land I feel for him. He's going to find the limitations real quick of a 70 hp tractors and the needs of lots of chainsaw time. It will wear you out to buck stumps, cut logs and limb them to mill standard. Then having to deal with the huge amount of slash and stumps. It's no joke
Brett
   / New tractor equipment and plan #17
My thoughts also after reading the first few posts.
   / New tractor equipment and plan #18
If the Pine trees are rooted like you think and they are and not to large, then your plan should work just fine.
We had to remove a bunch of naturally growing ones when we built our new place and unlike your trees they varied greatly in size and root structure. after renting the excavator we still had some to remove a while later.
I did push over a few small diameter ones with my similar weight tractor and other than worrying about which way the tree might fall if a wind gust should show up at the wrong time it worked OK .
The problem for me arose when I hit one with a tap root like this attached photo and It would not move so we cut it down and spent some of the day with the tractor a chain, chainsaw,shovels, pickaxe.
your plan of cutting the stubborn ones and then going after the stumps later sounds good-we also removed a few I cut down- and a was able to grapple the stump out in a single scoop year or 2 later on a rainy day(second picture)
There was not much rhyme or reason for the different root structures. Some were easy some not so easy.
ps. The safety factor of a construction duty ROPS when pushing over any tree with a good sized Ex or dozer-Priceless!
Please be careful
Nowhere did I ask for advice. I simply stated my plan and asked for peoples thoughts. I know what I am doing isn't the normal nor is it the most productive and efficient means to reclaim the land. Everyone seems to be stuck on the tree pushing over talk and fail to read further! I have been in numerous forums and shared ideas and given/received advice and never have I seen so much negativity. I bet I have more mechanical knowledge and ability along with more machinery and tractor time than everyone of the nay sayers in this thread! Imagine me being so stupid to be able to sit on the steel island I'm on now and be in charge of 80 men and over 100,000 horsepower running just feet away from me as I type and not having enough sense to know what I am doing. Thanks for talking down to me in my own thread guys, your negativity is only inspirational motivation.
   / New tractor equipment and plan #20
You didn't ask for advice but wanted out thoughts? I'm sure your are capable at your job and probably can drive a tractor. I don't claim to be able to do your job. Could I figure it out, maybe with some help. What your wanting to do is what I do. Something I'm very familiar with. I know or atleast have an idea of what works, what tears up equipment and what doesn't. You have 15 acres of pine plantation. How many trees is that? 400-500 per acre? 6000-7500 trees is a ton to do with a grapple and tractor. Now your talking about cutting them off with a tree saw and grinding that many stumps is one of the most ambitious things I've ever heard. If you saying your trees are chip/saw which is 6" tops the base is going to be decent still.
I genuinely wish you luck on your project. Just don't want you to get overwhelmed, hurt or equipment torn up and want for you to have a realistic expectation of what you will be doing. The other thing with shoving a tree with a tractor is it often doesn't break the roots out. Now your fighting with it. It's not like a dozer where you shove it over, drop your blades angle down to catch the root and push it out.
When you get home give an acre a try and see how it goes. You very well may be 100% right and I'm speaking out my butt however, I think your going to find this is a long long term project. If you don't spend time on a saw your burn piles will be a nightmare to deal with and a mess to clean up. Also, be careful around the stump holes so your belly doesn't get torn up or tip you over.
Brett
2013 Dodge Durango (A53317)
2013 Dodge Durango...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2020 BOBCAT E32 EXCAVATOR (A52707)
2020 BOBCAT E32...
Heavy-Duty D-Ring Shackle Set (A53117)
Heavy-Duty D-Ring...
