Need a heavy duty Brush Hog/Mower that is a good value on price & performance
   / Need a heavy duty Brush Hog/Mower that is a good value on price & performance #1
Tangoddess
Cleveland, TX
None yet
Hello,
The weekend is almost here!
It looks like we need a new Brush Hog/Mower whatever they are called for our used New Holland 3930 tractor.
We bought it used and the JD mower, model 513 I believe, was not good, it was broken from the blades, and my FIL is having a hard time getting it out.
He is ready for a new brush hog/mower that we can use on the property, it has tough native grass, about 8 acres.
In your opinion, which is a good, heavy duty brush hog/mower that has a good sweet spot of price and performance?
Thank you!!!
   / Need a heavy duty Brush Hog/Mower that is a good value on price & performance #2
There's a company down in Houston that's called Knox tractor. They sell a brand called titan for the best price around. I would consider them. There is also lots of brush hogs on CL that look to be in real good shape
Brett
Hi Rusty,
@rustyshakelford
Thank you so much. You are not in the Houston area are you?
Is Titan a good brand?
If you have any leads on CL let me know, I would be glad to look, and send you a gift card to thank you
What is a good size to get? 6ft or larger?
   / Need a heavy duty Brush Hog/Mower that is a good value on price & performance #5
Hi Rusty,
@rustyshakelford
We are west of you near navasota. I'll keep an eye out for sure and no gift card necessary
Brett
I spoke to Knox tractor, it seems like the Titan 6ft heavy duty brush hog, which is about 100HP and weighs 770lb for about $1500 and they have a lighter duty one which is 6ft weighs 726lb and 55HP for about $900
How does the pricing and specs on the heavier duty 6ft look - 100HP, 770lbs
   / Need a heavy duty Brush Hog/Mower that is a good value on price & performance #7
I don't have any titan stuff. When I was shopping for an 8' they came up and started checking into them. Was impressed with their quality. Seems like an older style but plenty stout. I don't know about the prices but know they have the best prices around.
What the best fit for your tractor is is harder to answer. I'm not familiar with the models weight, Hp and 3pt capacity
Brett
I believe these are the specs of the tractor. It is a New Holland 3930
Drawbar (tested): 38.18 hp [28.5 kW]
PTO (tested): 52.54 hp [39.2 kW]
3 point hitch Rear lift: 3,080 lbs [1397 kg]
PTO Rear PTO: independent
Rear RPM: 540
Engine RPM: 540@1800
540@1755 (shuttle)
The turbocharged 3.1-liter engine was introduced in 1999.
Which brand/size did you go with Rusty?
   / Need a heavy duty Brush Hog/Mower that is a good value on price & performance #9
Your 3930 will handle that 6' cutter easily. I run a 6' 472 Brown behind a 4610 SU. It specs similar to your 3930. The Brown is 1100#.
Thank you Turbys_1700
How much heavier and more HP can the New Holland 3930 turbo handle?
Can I use a larger cutter eg 7 ft or 8 ft
what number do I need to look for in the cutter as an indicator of size? HP? weight #
thank you!!!
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
E-Z Trail 680 Adjustable Head Cart (A50514)
E-Z Trail 680...
2017 Freightliner M2 106 24FT Box Truck (A50323)
2017 Freightliner...
2021 KUBOTA SVL 97-2 SKID STEER (A51242)
2021 KUBOTA SVL...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
