Which impliment
   / Which impliment #21
I just got done planting pasture grass on 12 acres for horses.
Absolutely kill whatever is growing w roundup first. Then I used roto tiller and then drag harrow. Then planted grass seed.
Ground is not as smooth as I would want a yard. If I were going a yard I would have probably tilled twice and dragged until the wheels feel off the tractor (since those were the tools I have).
Once you plant the grass what is the plan to water? W my 12 acres the plan was to pray for rain. W 1.5 acres you can help Mother Nature along.
   / Which impliment #22
How many passes after plowing to break up the sod?
It is a simple process. Garden is about 50x200. I have an old ground powered manure spreader. I usually put 2-3 loads of manure on garden and the plow it under. Then put tiller on and till garden. It tills easy and only one pass is needed. Till it all up in 20-30 minutes. You spend nearly as much time putting tiller on and off tractor an you do actually tilling. It does a really nice job, is very efficient, effective, and is easy on the tractor and tiller.
   / Which impliment #23
I'm not saying yea or nay on this Harley rake, don't know exactly what on is. I'd like to see it tie into some ground seeded down in brome grass. I'm not saying it won't cause I'm not sure what it is. If it will tear up a brome field I'm sold. You got to have a pretty good horse of a tractor to pull a plow through a brome field. Do you have any pics of this thing.
I don't know what brome grass is unfortunately, but it doesn't work like a tiller, it has small carbide knobs on the rotating drum (which does rotate similar to a tiller) which dig up the ground only a small amount at a time. I will typically go anywhere from 1" to 4" deep but usually somewhere in between. What it does is pull all the material out of the ground in front of the implement, and then there is a small opening that all the soil will go back through, which gets deposited behind the power rake, but the larger things like rocks, roots, old metal in the field etc, all get carried in front of it. At the end of the row you have a pile of debris with almost no dirt in it. Or you can windrow and push everything off to the side.
However, eventually you will have a pile of rocks or roots or what have you, to pick up with your bucket.
This job the op is trying to do, is THE purpose of a power rake. Absolutely the tool for the job.
Here is a before and after of some heavier duty use.
   / Which impliment #24
Maybe hire the job out?
When viewing implements look at it as a cost of doing a job. AND, no one says you have to hang on to the implement after it's done the job that you got it for: resell it!
I bought a dump trailer to facilitate a job I was doing on my property. $4k! It did the job, did exactly what I needed it to do (saved my money that I would have had to shell out for someone else to do the job), paid for itself and now is available for whatever else I may need it for: I could resell it and get some money back, but dump trailers are really handy; and, I've got an infinite supply of materials (and possible need) from a neighbor, for free!
Anyway, don't get too hung up on acquisition costs. Also consider resale.
   / Which impliment
Thanks for all the reply痴 and info guys, you gave me some ideas that I can make work. As far as all the, what I would call 都pecialty equipment goes, they are definitely out because I live in a remote northern community where none of that stuff is available to purchase let alone rent. I did check with a buddy that has a kubota B series tractor and he actually has a pto rototiller that I can borrow. I think it will work fine for breaking up the land because it is sandy soil and isn稚 hard at all. I also have a drag for leveling and smoothing cross country ski trails that would probably work. It痴 6 feet wide and 8 feet long. I will do most of the leveling with my loader bucket and then finish it of with the drag.
Thanks again for the info and ideas
   / Which impliment #27
Spray it with Roundup.
Mow it as absolutely close as possible.
Borrow a small plow or rent a rototiller.
Depending on how much dirt moving you have, a box blade 'could' make your life easier. If its only a bit, you could do it with the FEL, although I think your ultimate outcome would be better with a box blade.
If you have sprinkler irrigation, Broadcast the seed and then rent a roller to firm up the seed bed and improve seed/soil contact. You can rent a straw bale blower from SunBelt or other equipment rental store... OR... you can just break up straw bales by hand and spread it over the yard. Keep it well watered until well established and you will be the envy of your neighborhood.
If you can't rent because of location and lack of rental locations... I'd look for a box blade on Craigslist and do the above. Hand spreading straw isn't that tough... just monotonous.
   / Which impliment #28
Thanks for the explanation, that helps give me a good idea. As far as brome grass, I'm starting to think that maybe a Midwest thing cause you are not the first person who is unfamiliar with it. It kind of grows naturally here along road side and what not. It is kind of hard on the ground (drains the nutrients) so if you want to use it for hay you have to fertilize it every year to get a good hay crop. It has a tremendous root system that sort of spider webs beneath the soil. If you want to plow it under say to plant corn or soybeans it is best to spray it first. When you go to plow the terraces, boy does it pull and beak hard. As far as the grass and hay feature, it depends on how well you fertilized it. Properly fertilized it will be pretty thick and waste high. It make for an excellent choice of hay for cattle. Hope this helps.
   / Which impliment #29
ANY vegetation that could be used as fodder/feed is going to be used for its nutritional content. All extracts from the soils, thus depleting it. Soils rebuild, but WAY slower than we will allow them: soil microbes and rocks/rock dust being the main resuppliers.
I have Reed Canary grass, which, I believe, is probably similar to the brome grass: I've measured a stalk at 9 1/2'! I don't use chemicals, never will: I have animals; and, I basically refuse to use it- watershed area. I have found that repeated mowing will eliminate it, of course, this isn't likely the "solution" the OP is looking for (but for those who aren't in favor of chemicals and are patient then this is a way). I have similar issues with blackberries: takes years of mowing and they'll eventually give up; all mulching helps build up the soil for better grass (which supports healthier soil microbes).
   / Which impliment #30
I'll challenge you on that. Red clover, soybeans, lespadesa are all used to rebuild the soil. This is wht you always plant soybeans behind corn. Corn tends to drain the soil while beans tend to replenish the soil.
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2019 KENWORTH T680...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
John Deere 6110M (A60462)
John Deere 6110M...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
