Changes to new F2690
   / Changes to new F2690 #21
.... A couple of points about the recommendation from arto98607. The wheels he linked too are the right size, but they are white instead of orange (if that matters to you). Also the axle for the wheels would take a fair amount of work to make. I have a lathe and welder and I could make the axle from drill rod as arto98607 suggests, but new axles were $40 each on eBay and my time is worth more than that if I were to make them myself. They are not simple:
OK I understand.
There is a noticable difference in the design!
My F3060 has a rear discharge deck (RC72R-F30) with very simple axle shafts of straight 3/4 inch "rods" with 5/32" cotter pin holes drilled at each end.
Photos before any cleaning of mud etc.
The old tires are Marathon Flat-Free 9 x 3.50 - 4 inch wide solid rubber tires, with few big chunks of tire rubber missing - however they could still be used but look pretty ugly.
I am in the process of installing a new replacement deck shell and rebuilding or repairing anything that's worn out.
This is a 3500 hour ex. municipal mower where the deck was simply operated too close to the ground (in my opinion), which caused lot of wear in the deck parts. The deck wore out but the good news is the rest of the mower was serviced regularly and is in good shape!
:ambulance:
   / Changes to new F2690 #22
$8 each shipping for me but nothing says this is a solid rubber tire on their page plus the other tires on the page of the same size don't look to be solid. I guess your positive it's solid rubber with no tube or valve stem?
I'm quite certain that it is a flat free solid tire as that's the only kind of tire that Amerityre produces - their website: Mower Tires Archives - Amerityre Corporation
No tubes and dealer said it was a solid tire
   / Changes to new F2690 #24
I emailed my Kubota dealer and they are unable to find a solid tire kit from Kubota for the mower deck.
So do we know what tires are needed to be ordered, using the factory bolts etc? I have a F3990 with the side discharge and would love to switch over to solid tires.
   / Changes to new F2690 #25
I have a set I'd sell for what they cost me, pm me.
Here are a couple of pictures of the tires. The factory rims were used.
   / Changes to new F2690 #27
Are they completely solid or do they have a hollow core. Will they flex any?
   / Changes to new F2690 #28
Don't know about the Amerityre, but the Carefree ones I have are a high density solid polyurethane foam, flexes a bit, probably about the same as a properly inflated pneumatic, maybe a bit less. The nice thing about the gauge wheels on these mowers is they are a three piece wheel. You can unbolt the wheel half's and assemble them back together inside the solid foam tire. With one piece wheels, you have to have them pressed onto the rim using a special cone and press.
Thus, these wheels can be converted to solid core by just purchasing the tires. I bought the tires and then discovered I needed new wheels (roller bearings worn out) I have since found I can by the wheel and solid tire combo for less than buying them individually so I am selling the tires.
You can buy the tires direct from from Carefree Tire - part number TI-9350-4275S.
9/3.5-4 inch Smooth Tire, 2.75 inch Bead Width - Carefree Tire
This is a 9 x 3.50-4 (2.75 bead width) for $24.95 each plus shipping and tax (if you live in TN). There are other sources and brands - Ameritye like 628pm has - being one. Be sure you get the 2.75" bead width. Available on eBay as well. If you are shopping for the wheel / tire combo, be sure you know your shaft size and hub width. Many suppliers list the 4" x 5/8" hub as correct for these decks. Mine needs a 3/4" x 3 1/4" hub.
I was lucky to find new axles on eBay for a reasonable price as well. Keep these wheels greased.....
Good luck.
   / Changes to new F2690 #29
I'll have to double check and make sure the wheels are any different on my 2014 72" side discharge. I would assume they are the same....
Ordered the mulching kit for the f2690 on Friday, dealer said I would get it this week. I bought an extra set of blades when purchasing the F, dealer said he would take them back. Dealer in Okawville Illinois has always worked hard to meet my needs. I do like to buy local if I can.
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
CATERPILLAR H90C HYD HAMMER (A52707)
CATERPILLAR H90C...
CAT Quick Attach Forks (A56469)
CAT Quick Attach...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
3ft 5-Point Metal Star (A55853)
3ft 5-Point Metal...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
