Shoud I trust Chinese chain and ratchet binders for hauling?
   / Shoud I trust Chinese chain and ratchet binders for hauling? #11
I have 2 good US made folding ratchet binders along wit a few Harbor Freight class ratchet & lever over center type. I prefer the US made ones because of the better action & folding handles. But the cheap ones work just fine.
I've taken to using the over center ones to hold down the loader as that's not falling with or without a chain on it & the over center style is faster. I don't work about getting it super tight. I chain the front of the trailer to whatever end of the tractor is there, then drive backwards until tires spin to tighten. Low range, 4wd & parking brake to hold it. Then I chain up the rear of the trailer with the US binders until everything is way tight. Then lower the loader & 3pt ( if anything is on it) Then chain the loader & impliment down. Usually 2 seperate chains on each end to clevises on the front bumper. Occasionally 1 chain through the clevis in the drawbar on the rear to 2 seperate points on either side. Usually 2 seperate chains to some other clevises near the tires on the rear though.
Never had an issue with Harbor Freight chain or binders.
   / Shoud I trust Chinese chain and ratchet binders for hauling? #12
I prefer the lever binders. After a while in a toolbox the ratchet binders rust up and don't work right.
   / Shoud I trust Chinese chain and ratchet binders for hauling? #13
RATCHET BINDER - FOLDING HANDLE RATCHET BINDERS
I bought 4 of these to secure my tractor on the trailer. Very easy to use and eliminates the lever type binders that can snap back and hit you if you are using a cheater pipe ! The folding handles is a plus also. Not sure where they are made but they are heavy duty and good quality.
I'm also using these style binders, mine sourced from Northern Tool, I'm sure import, but decent quality. My G70 chain was HF on sale, and I dedicated them and binders to tie-down only, I don't drag as I've got a couple other chains I use to tug, pull, drag, etc. so if they get dirty or damaged I can still trust my tie-down stuff. I really like the binders as you can fold the handle and put padlocks on to secure - those things seem to grow legs in parking lots very quickly.
   / Shoud I trust Chinese chain and ratchet binders for hauling? #14
I had G70 chain from someplace else and bought HF heavy duty load binders and they are very heavy and work great. Just spray some oil on them so they stay free from sticking or rusting.
Those folding handle ratchet binders look interesting. So, the reason they are better is because they don't rust up and you can lock them?
EDIT...oops...yes, and the folding handle.
   / Shoud I trust Chinese chain and ratchet binders for hauling? #16
You need a liberal dose of sheep oil, or Fluid Film.
I thought the main point was the handle folds up.
   / Shoud I trust Chinese chain and ratchet binders for hauling? #18
I've switched to locking lever style binders and never use the other style anymore. I haven't looked lately but Lowes use to sell the 5/16 grade 70 chain made in the US by Campell. I haven't seen it in a little while so they probably now sell a Chinese brand. I bought 4 20' lengths of it.
Did you switch just for the locking aspect? Have you ever used the ratchet type?
2019 Chevrolet AWD Equinox SUV (A55853)
2019 Chevrolet AWD...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
1635 (A57192)
1635 (A57192)
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A55851)
2025 Kivel 42in...
2011 FORD F-450 (A52472)
2011 FORD F-450...
