1949 8N Won't Start
   / 1949 8N Won't Start #102
Thanks, I appreciate it.
Can post picture later, mine is very crude compared to what others have built.
put 4ft 2x4 uprights in each side of pallet, with 45° braces front to back, and one brace from each to middle of pallet.
Back phd up to it as high as you can lift, put a 2x4 crossbar under phd arch, on the upright posts. Some people put a saddle on the uprights to easily remove and install the crossbar. Lower phd on crossbar and unhook with it hanging.
   / 1949 8N Won't Start #103
I just used my impact driver, some screws, and scrap wood. Looks like crap but it works. I move it around in the barn with pallet jack. I try to keep stuff stored on pallets .
   / 1949 8N Won't Start #104
That's a tough one. Were it a Deere,New Holland or even a Ford hundered series, there are multiple tricks but I think you need an 8n for each empliment unless it's a FEL then you can have something on the rear also.
An 8n and a hundred series should be virtually identical in 3pt hookup / hitching implements.
Thanks, pictures would be great, if you get a chance.
If you get a chance, can you post a picture of it. Like you, I'm more concerned with function than looks.
I didn't realize there was a difference in 3pt hookups. I thought they were universal for all tractors.
   / 1949 8N Won't Start #108
Jaxs, thanks for the info, but I'm not interested in learning all the instructions and outsee of the tractors. I just need to be able to keep my 8N running and working.
   / 1949 8N Won't Start #110
Will try to find one. Neighbor has my phd right now.
Unused 2025 CFG XZ20R Mini Excavator (A50322)
Unused 2025 CFG...
John Deere 7130 (A50120)
John Deere 7130...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
2018 JOHN DEERE 310SL HL BACKHOE (A51406)
2018 JOHN DEERE...
2019 Ford F-350 4x4 Ext. Cab Palfinger PSC 3216 4,000LB 2 Ton Mechanics Crane Service Truck (A50323)
2019 Ford F-350...
