1949 8N Won't Start
   / 1949 8N Won't Start #102
Thanks, I appreciate it.
Can post picture later, mine is very crude compared to what others have built.
put 4ft 2x4 uprights in each side of pallet, with 45° braces front to back, and one brace from each to middle of pallet.
Back phd up to it as high as you can lift, put a 2x4 crossbar under phd arch, on the upright posts. Some people put a saddle on the uprights to easily remove and install the crossbar. Lower phd on crossbar and unhook with it hanging.
   / 1949 8N Won't Start #103
I just used my impact driver, some screws, and scrap wood. Looks like crap but it works. I move it around in the barn with pallet jack. I try to keep stuff stored on pallets .
   / 1949 8N Won't Start #104
That's a tough one. Were it a Deere,New Holland or even a Ford hundered series, there are multiple tricks but I think you need an 8n for each empliment unless it's a FEL then you can have something on the rear also.
An 8n and a hundred series should be virtually identical in 3pt hookup / hitching implements.
Thanks, pictures would be great, if you get a chance.
If you get a chance, can you post a picture of it. Like you, I'm more concerned with function than looks.
I didn't realize there was a difference in 3pt hookups. I thought they were universal for all tractors.
   / 1949 8N Won't Start #108
Jaxs, thanks for the info, but I'm not interested in learning all the instructions and outsee of the tractors. I just need to be able to keep my 8N running and working.
   / 1949 8N Won't Start #110
Will try to find one. Neighbor has my phd right now.
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
AGI - Westfield MKX 13-94 Swing Away Auger (A50514)
AGI - Westfield...
Towable Orchard Sprayer (A51691)
Towable Orchard...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
