What are good concealed carry choices for women?
   / What are good concealed carry choices for women? #41
Someone already mentioned this but it really needs to be the first decision. Will the woman actually use the weapon if needed? She needs to be sure she will use the weapon otherwise don't waste the time and money to get a firearm and a CCW. MANY people will NOT defend themselves. Many years ago I was in a defense tactics class and the instructor laid out a scenario that took out all of the variables of using deadly force and asked who could pull the trigger. Only about a third of the class raised their hand. :shocked: How those people got that far into the process and training without raising their hand to that question was shocking to me. Scary it was. :eek:
First let her pick the handgun. It should be whatever fits her hand. Look for a range where you can rent some weapons and let her shoot them to see what works and does not work. She needs to have confidence in the weapon and her ability to use it. Going to the range will allow one to find which cartridge works best for her in a given weapon. I would start at 9mm and go from there. Generally speaking, larger framed handguns handle recoil better than smaller weapons but larger weapons make concealed carry more difficult. Furthermore, women's hands are often smaller than men and a smaller frame weapon is needed for a good fit. Some weapons will recoil more than others due to design and materials, lighter is easy to carry, but that can lead to more recoil. Recoil does not bother me that much until the handgun gets into the magnum power range but I have good hand and arm strength. It really is an individual thing that balances the needs/wants for concealed carry, weight, size and bulk vs capacity, caliber, and fit.
Once upon a time, I was shooting with my wife and I was giving her hints on how to improve what she was doing. No yelling or screaming on my part at all but there was a bit of resistance from her to do what needed to be done. :rolleyes: That day, or the next day, we went to a gun store that has a woman owner/firearms instructor. The lady spent 2-3 hours with my wife! :thumbsup::laughing::laughing::laughing: She let my wife hold a bunch of handguns to find a fit and they then went off to shoot at a laser target for quite some time with some of the handguns. The woman instructor was making suggestions which my wife dutifully followed. What was funny is that these were the same comments I made but which were met with resistance. :confused3::D:D:D On the way home I DID mention this to the wife. :D:D:D
So find an instructor the lady will learn from. :D
Which cartridge to use is really what round the woman can best carry and shoot. A .22 LR is better than nothing.
I have seen women who have trouble racking a slide. Really hard for me to understand it but I have seen it. I think this can be overcome with technique and doing some simple hand strengthening exercises. Having said that, I would not let difficulty of operating the slide prevent her from getting a pistol as long as there is someone who can do it for her. :eek: Yeah, I know that will raise some eyebrows but how many women carrying a pistol carry a second magazine? Pretty close to zero. With even the smaller frame pistols, especially in 9mm, they have plenty of capacity. In a critical incident, the most likely reason anyone would have to rack the slide is if there is a malfunction. No argument that one SHOULD be able to rack the slide but if the pistol is what fits the woman, she can shoot it, and she will carry it, so be it. Pistols are not as wide as wheel guns and that might make the difference in being able to carry concealed.
The reality is that for most incidents where a woman is going to use a handgun, she is going to have a very short time to use the weapon, and if it malfunctions, she very likely will not have time to fix it. Tap, rack and go is not hard but it does take practice and I don't think most men, much less women, have practiced enough to have the muscle memory to clear a failure to fire without thinking. I have fired thousands of rounds in pistols and I have had some failures to fire and I did not even think about what to do, I just did it, but I have spent the practice time. The rounds that failed to fire were practice rounds and I have never had a duty round fail to fire. Knock on wood. :D
I have seen a revolver jam and it aint pretty. Dang scary.
Never seen anyone who has trouble pulling the trigger though. That one really is odd. Having said that I would NOT get a DA/SA handgun. The DA trigger pull on the handguns I have fired has been around 12 pounds with the SA about 5-6 pounds. Training to pull a 12 pound trigger with accuracy AND then training for the less SA trigger is a PITA. Given one can buy modern pistols that have the same trigger pull from the first round to the last, I don't see any reason to have a carry handgun that is a DA/SA. The trigger pull should be the same every every time.
Later,
Dan
Pretty sage advice Dan. As for the "husband" thing, I have seen that countless times. If you are the woman's husband, forget about it. Most wives won't take critique even the best intentioned and carefully worded critique from their husbands. Get someone else to train your wife on technique. Get an "expert". You likely aren't. And even if you are, you don't count. As for the the revolver, semi auto choice. I still say leave it up to the woman if she can handle the semi auto, and shoots it well and can load, clear malfunctions and manipulate it safely, why not? Of course the revolver drill is easier, and if there is any doubt she can operate a semi auto, then revolver it is. Some women really like revolvers, but some don't. I always introduced both, and let them fire as many rounds as possible through both, and fully load, unload, and manipulate both. There is something to be said for the simplicity of the revolver even when neglected, but they can and do fail occasionally. But not very often.
   / What are good concealed carry choices for women? #43
They really are knowledgeable about what they are reporting on...... "Storm Ruger"
:rolleyes:
   / What are good concealed carry choices for women? #44
:rolleyes:
No less should be expected from one of the slimiest pump and dump stock analyst ever...(jim cramer)
   / What are good concealed carry choices for women? #45
My wife, 61 years old carried a .38 S&W hammerless revolver until she got a hold of my Keltech .380. Now, that is all she carries in her purse. It's super light and powerful enough to end a fight. At least she carries it all the time and that's all I was looking for.
So just to get back on here with an update. I still appreciate all the suggestions and am taking them all into consideration.
Next week I have a session lined up with the 2 female family members to do some shooting. The one family member has a few choices and I am borrowing another few options from one of my friends that is very knowledgeable and quite the collector.
This session should start steering the direction. This will be revolvers and semi-autos in several sizes and different manufacturers.
FWIW, we can shoot at several outside locations around here including my back yard. We don't have an indoor range around here anywhere close by. We also have a DNR range about 30 minutes drive.
In further research, I went to a local shop and spent some time looking at inventory and asking advise there too. Ironically, I think I might have found my next personal choice. I really liked the Glock 42 in 9mm.
A woman shouldn't carry unless she will pull the trigger. Many won't.
I'll have this discussion too. At least 4 of you have mentioned this so far and I know that is important. I figure it's better to ask after she's had some time shooting to see if it will appeal at all in the first place.
I'm not trying to push her into anything, just from my side want her to be able to defend herself if it ever came to that. It's pretty scary knowing that when she called me with her situation a couple weeks ago, I was an hour away and couldn't get there to help at all. Another woman at the business she was at has a revolver, but it was out in her glove box in the parking lot doing no good for anyone (bet she'll never leave it in her car again). If she decides she's just not interested, we won't pursue a purchase or a CCW class.
   / What are good concealed carry choices for women? #48
Going thru the same thing with my wife, she says she doesn't think she could pull the trigger on a person, that's her feelings right now. BUT
Who knows what it will be tomorrow, or next year, or???
In the meantime she has learned to shoot a handgun(nra class, not me;) can hand in her paperwork in Oregon whenever she feels like it(don't need a permit here)
She actually will suggest we go shoot sometimes:)))) so even if she never carries I figure it was money well spent, just adding another life skill to her list.
Btw her pistol of choice is an xdm in .40 with the big grip extensions. She doesn't even like the xds (too small to hang onto)
She even likes to shoot the .454 casul but only with .45 long colt in it, lol I feel the same way about that pistol.
   / What are good concealed carry choices for women? #49
Glock 42= single stack .380
Glock 43= single stack 9mm :)
   / What are good concealed carry choices for women? #50
Get some pepper spray, change job, stay away from bad areas. Be home and in bed by 1000pm. All your necessity for a fire arm and training goes away. Problem solved.
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
Pallet of 22 Misc Wheels (A51573)
Pallet of 22 Misc...
JOHN DEERE WHP48A LOT NUMBER 107 (A53084)
JOHN DEERE WHP48A...
2000 Wabash National 53ft T/A Dry Van Trailer (A51692)
2000 Wabash...
Quick Attach Skid Steer Plate (A51573)
Quick Attach Skid...
