Fallon
Super Member
I have 2 good US made folding ratchet binders along wit a few Harbor Freight class ratchet & lever over center type. I prefer the US made ones because of the better action & folding handles. But the cheap ones work just fine.
I've taken to using the over center ones to hold down the loader as that's not falling with or without a chain on it & the over center style is faster. I don't work about getting it super tight. I chain the front of the trailer to whatever end of the tractor is there, then drive backwards until tires spin to tighten. Low range, 4wd & parking brake to hold it. Then I chain up the rear of the trailer with the US binders until everything is way tight. Then lower the loader & 3pt ( if anything is on it) Then chain the loader & impliment down. Usually 2 seperate chains on each end to clevises on the front bumper. Occasionally 1 chain through the clevis in the drawbar on the rear to 2 seperate points on either side. Usually 2 seperate chains to some other clevises near the tires on the rear though.
Never had an issue with Harbor Freight chain or binders.
