Dewalt Cordless Grease Gun Deal
   / Dewalt Cordless Grease Gun Deal #21
Check the pawn shops. I bought a Lincoln last spring for 60.00 and I love it. I was also amazed how fast you can go thru the grease in half the time
we have found that the Lincoln works ok, but dewalt seems to be holding up better. time will tell
   / Dewalt Cordless Grease Gun Deal #22
lock-n-lube won't get on half the fittings on my backhoe. I have one on one of my guns but rarely use it.
I gave mine to a friend on here, Murph.
   / Dewalt Cordless Grease Gun Deal #23
I have the 18v DeWalt version... Been two seasons now. Absolutely love it. My hand and pneumatic grease guns are long forgotten now.
It'll amaze you just how quickly you can go thru a tube of grease!
Yep, bought mine 3 or 4 years ago. Only end up using a manual gun because my equipment is in two locations and I forget to take the DeWalt with me. :)
   / Dewalt Cordless Grease Gun Deal #24
I quit using the LnL when I got the Battery powered gun. It's soooooo much faster that taking the time to mess with the LnL seemed totally non productive. Since I totally have a free hand all the time with the DeWalt I had no need for a locking coupler anymore.
Long term you will come to value your Battery powered grease gun as one of the best tools you've ever purchased. :)
   / Dewalt Cordless Grease Gun Deal #25
I got the 18v Milwaukee and never looked back. There is another lock on besides the loc-n-lube. It works like a mini air coupler. I got it for 8 bucks at a JD dealer. Same size as a standard one and works great. Any brand gun would probably be fine and for the newer ez lube axles on trailers, It's amazing how fast you can run a tube of grease through them
   / Dewalt Cordless Grease Gun Deal #26
I bought one of those as well. Can't remember the brand name? It is tidier than the LnL by a lot. As you described, it is useable in tight spaces because of it's compact size. But then that creates a problem which when it surfaced caused me to give it away as well. To unlock it you have to be able to grip the collar and pull it rearward just like uncoupling an air hose. If the zerk if recessed or in a tight spot you can't release the coupler....... :(
I gave it to Murph as well. Well,,,,, gave is a loose term..... I tried to give them both to him by mailing them with no complete return address. He lives in Ohio. The smart guy he is, he hunted me down and mailed me a gift certificate to Wal-Mart. :D
Yeah I have one fitting on my backhoe boom that is up in a hole. No way to use anything but a push/pull coupler on that one.
I ordered a 10pk of Amalie 5% moly grease to try. Hope it arrives without bent ends. Was buying a couple of tubes of 3% in TS and all but one tube had the ends bent so I didn't get them.
   / Dewalt Cordless Grease Gun Deal #28
I love my Lock n Lube. I'm waiting for Ryobi to get off their *** & release a One+ grease gun. Have 8-10 One+ batteries between the house & shoop. Passed 20 One+ tools last I counted. I love having multiple drills & impact drivers so I don't have to change bits on a project.
   / Dewalt Cordless Grease Gun Deal #30
I bought the 20v dewalt on Amazon as a kit. I didn’t have any of the other batteries and I wanted the case. The case alone was worth it. I didn’t think it would be worth it as I usually used my air compressor gun which broke and I was about to replace. The dewalt was expensive but worth the money. I can grease my entire tractor and loader in a few minutes without moving the tractor from where it is. Looking back it was well worth the investment. I grease much more often now, anytime I feel I need it, rather than putting it off in between jobs when I had to move the tractor.
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A55314)
BOSS 990 Fuel...
John Deere 5055E (A53317)
John Deere 5055E...
2007 Ford F-450 4x4 Cab and Chassis Truck (A55852)
2007 Ford F-450...
2015 Ford Transit 150 Cargo Van (A53422)
2015 Ford Transit...
