Pump water above ground without freezing
   / Pump water above ground without freezing #1
LittleBill21
Elite Member
PA
Mahindra Max 26XL, White
so i have a couple projects where i need to run a sump pump out to a yard, and dump the water above ground. my issue is figuring out how to deal with the pipe that goes from below frost level to above ground to get rid of the water. there is no way to drain to a lower area, has to just be pumped to a different section. its needs to be automatic as i can't drain the pipe manually.
any idea's?
   / Pump water above ground without freezing #2
CAn you build an enclosure for the vertical rise of the pipe as put heat tape on that portion of pipe. The remainder of the pipe should be a continuous fall to discharge. Flowing 50 degrees water will be slow to freeze.
   / Pump water above ground without freezing #3
Drill a small hole in the pipe below frost so it will drain back when the pump quits.
   / Pump water above ground without freezing #4
There are spring-loaded drain valves that pressure closes. (if your system makes any pressure)
Bruce
   / Pump water above ground without freezing #5
Heat tape works in a pinch. The pipe should rise straight up as high as needed out of the pump and then drain at about 2% to the low point. Then the only part with sitting water is the first little bit. As stated, if you can drain that first rise without creating an ice skating rink that will work too.
   / Pump water above ground without freezing #6
I have installed a few pumps with freeze situations.
One tactic is to drill a small hole in the check valve so that the cold exposed section drains itself dry.
The other is heat tapes.
   / Pump water above ground without freezing #7
Here is what I did for our house. The end of the drain line is at or above the level of the sump pump so just putting a hole in the check valve wouldn't work. The line comes up off of the pump goes through the elbow, through the tee and outside. The well foot valve let's everything from the tee on drain down, but doesn't let water leak out.
Aaron Z
no, there is no power, as some of the drains are over 100 feet long
this is a pretty solid idea. i will prolly try this.
can you explain this better? where does it drain back into the sump pump area? that won't work if thats the case, the pump would keep turning on, some of these runs are over 50 feet.
maybe i have a better under standing. you add the check valve close to where the pipe freezes? then drill a hole there? that makes alot more sense
John Deere 1560 No Till Drill (A52349)
John Deere 1560 No...
2015 Genie GTH844 Telehandler (RIDE AND DRIVE) (A50774)
2015 Genie GTH844...
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A50323)
2007 Kenworth T800...
2020 Steiner 450 Slope Mower (A51573)
2020 Steiner 450...
Millcreek Row Mulcher (A50120)
Millcreek Row...
New Holland 474 Haybine (A50774)
New Holland 474...
