LittleBill21
Elite Member
so i have a couple projects where i need to run a sump pump out to a yard, and dump the water above ground. my issue is figuring out how to deal with the pipe that goes from below frost level to above ground to get rid of the water. there is no way to drain to a lower area, has to just be pumped to a different section. its needs to be automatic as i can't drain the pipe manually.
any idea's?
any idea's?
