Two Alternators On One Tractor?
   / Two Alternators On One Tractor? #11
He probably won a lot of thirty 30-50inch LED bars...
Three under the tractor.. three in the grill... six on the cab.. two on the backhoe.. three on the loader.. one in the engine bay.. two on the bucket...
Rumours say when the flux capacitors is charged enough to power them all, Australia's solar panels work at 50% capacity...
But on a serious note, on a bigger tractor I can see the use of having a second alternator...
The bigger tractors simply have more room /power to spare and space to mount electronics/lights etc.
As for the 120v power...
I'd get a 1200W silent inverter generator... really quiet.. briefcase size.. and would cost less /use less fuel /provide more power than having a converter..
Over all tractors don't have the big current draw even with all the lighting you can imagine and cameras etc.. since most things can be powered off hydraulics.. now if he had in mind some kind attachment that uses electric cylinders and motors etc.. then it would be useful..
Gotta remember that a led bar gives way more light than the old 50W halogen lights.. now if you had half a dozen of those mounted then maybe a second alt would be needed/helpful..
   / Two Alternators On One Tractor? #12
Today I happened to come across the original alternator that I had replaced on my Kubota B9200 a while back. ...
Given the vintage of your machine, I'd be wondering if it is even an alternator (higher output) as opposed to a dynamo (lower output)
My B2910 - a more recent machine - came stock with a dynamo ... although there is a higher amp alternator option available for it from Kubota.
   / Two Alternators On One Tractor? #13
Here's a thought. If you have room to mount the second alternator, a regulator, and in inexpensive inverter, you could have onboard 120v AC power for small tools and appliances. Don't know if you'd need a small dedicated 12v battery between the regulator and the inverter to stabilize the output.
Further to this idea, I don't know the output of your spare alternator, but whether it would be large enough for this would depend on what tools you'd want to power. Ditto with the second battery you'd install. I did a quick search online and came up with a thread on another forum from 2011 that discusses doing this. Heck, you might even find a YouTube video on it by now!
http://www.mytractorforum.com/74-barn/214924-inverter-question.html
   / Two Alternators On One Tractor? #14
[snip]
True, but maybe not as much fun! :dance1: I remember seeing an article years ago in "Four Wheeler" magazine showing how to install an onboard inverter for AC power in, I think, a Ford Bronco. The receptacle was mounted in the grill! The article did discuss the sizing of the alternator and said upgrading might be necessary for some vehicles.
The newer inverter-style briefcase generators are sweet, and much cheaper these days (see Harbor Freight's newest entry). But they're not all that lightweight, and would still need to be carried on the tractor somewhere. I'll carry a small 3000w generator on a carryall when I know I'll need AC in the field. But having power already on board would be nice.
Already have all the LED lighting installed that I need and enough remaining capacity with the existing electrical system.
Just wanted to discuss the idea of two alternators.
The B9200 has just the dynamo.
Edit: Well I do have a 2000 watt inverter generator. Perhaps I could mount that on the hood. :)
   / Two Alternators On One Tractor? #16
You can't parallel two alternators on the AC side (upstream of the regulator) unless you run them in phase lock. That is pretty much impossible on a tractor. You can parallel them on the the DC side. The generator with higher voltage will take all the load until it maxes out then the second one will start to contribute.
What is the main difference between a dynamo and an alternator? Output?
   / Two Alternators On One Tractor? #18
The dynamo has permanent magnets inside to create the magnetic field. The alternator has coil winding to create the magnetic field and thus can be regulated as far as its power output by adjusting the current provided to the field windings.
With the dynamo, it puts out power based upon engine rpm. The rectifier converts it AC output to DC to charge the battery. Excess power is just turned into heat in the rectifier.
Some model early Kubota's had dynamo's with 3 output wires whereas most have only 2. On these machines, only part of the dynamo output was rectified to DC to charge the battery. The remaining AC output was used for lighting which, in those days was incandescent bulbs who did not care if they were fed AC or DC.
When someone with one of these tractors with AC powered lights embarks on a project to replace the original lights with LED's, they quickly get a big surprise as the LED, the D standing for diode, does not like and usually wont run on AC.
Dave M7040
   / Two Alternators On One Tractor? #19
An entirely different concept...This idea and picture was posted here several years ago...it was meant to utilize the mid PTO...
Dave M7040
Very interesting! Thanks for the explanation.
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
1997 WESTERN STAR DUMP TRUCK (A60430)
1997 WESTERN STAR...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2017 Caterpillar 249D Compact Track Loader Skid Steer (A59228)
2017 Caterpillar...
