help bucket pin came out of new backhoe bh92
   / help bucket pin came out of new backhoe bh92 #1
Green Acres Homestead
NewBrunswick & Nova Scotia www.lostcaper.com
Kubota L4740 sold. As of Jan 2023 I have a new L2502.
I got about 30 hours on my kubota backhoe implement and when digging I noticed the bucket pin was sticking out several inches on one side. I inspected and the pin pushed far enough out that I had to line up the buck and pound the pin back in.
two questions.
1. The bolt that goes through the pin was not anywheres to be seen... Is this normal to loose the bolt and the pin back out.
2. Did I reinstall the pin properly..... After pounding the pin back in I lined up the bolt hole and put in another bolt. Something doesn't look quite right. The grease end is sticking out farther than all the other grease ends. Is that normal for the bucket pin. Is there a certain way to install the pin and grease nipple end.
   / help bucket pin came out of new backhoe bh92 #2
two questions.
Yes. My Kubota BH is the QA type and the original QA pin was secured by a simple spring-loaded linchpin. It failed one day and nearly bent the hoe end when the pin slid halfway out. I've seen that pin retainer used on other new Kubotas, too. I hope it isn't a standard fastening. If that is what yours was using, don't waste your time looking for it; the linchpin in the photo is the wrong way to secure any bucket pin. Use a more positive method. A double-nutted bolt will do as well as anything.
Don't know about your second question. In my QA system that pin doesn't have grease nipple. All the other pins seems to be the right length and are retained by thru bolts. Only that one pin had a linchpin for a retainer.
rScotty
   / help bucket pin came out of new backhoe bh92 #3
Looking at pics of mine, both pins on the bucket should look the same.
Looking at a picture, looks like my top bolt is missing, was there in delivery pictures. Too sick to go out and look.
Mine is not QA.
   / help bucket pin came out of new backhoe bh92 #4
Pin did not grow longer with use. If the pin is longer it getting exposed to more dirt and this led to the bolt coming loose. You might have noticed it when greasing if the pin was pushed out. If it was pushed out on the head side you may not have picked up on it. Double nutting sounds safe. Good catch on your part- when bent things are harder to put together.
   / help bucket pin came out of new backhoe bh92 #5
Loosing that pin is bad. Repairs could be over a thousand. Toss the linchpin and use a double nutted or teflon nut.
   / help bucket pin came out of new backhoe bh92 #6
IF, and that's a big if, you anticipate changing buckets often there are other shape of retaining pins that are relatively easy to swap by hand but are rarely lost.
For example the guy that dug a trench for my water line changed buckets a couple of times, used a real narrow bucket going across my driveway, bigger bucket for the rest of the work.
Yeah I would like to get a quick change system with several buckets.
   / help bucket pin came out of new backhoe bh92 #8
Those type of pins should not be on ground engagement equipment. I suggest you find another way to secure that pin before you really damage something.
Just because it came that way dosnt mean its good.
thanks. I will be sure to look into a property bolt.
The pin was retained by a normal bolt and nylon thread. Looking back I think what happened was I was taking out a big stump and the stump fetched up on the bolt and maybe broke the bolt off. Than after the bolt broke the pin backed out.
rScotty
good idea. Think I will go on search for a better pin.
   / help bucket pin came out of new backhoe bh92 #12
I don't have a backhoe attachment but every "pin" on the bottom side of my 3-point and ALL implements - I have replaced with a grade 8 bolt and Nylok nut. I was, at one point, loosing lynch/hair pins like they were going out of style. Never damaged or lost anything except the hair pins and the lynch pins.
And, quite honestly, I don't have a lot of brush to speak of.
   / help bucket pin came out of new backhoe bh92 #14
I have found some linchpins that snap closed tighter than a big 'ol rat trap. You have to be careful with them, been snapped more than once, but they definitely are more secure than the standard linch pin. About the only thing I've found that is close to 100% is the grade 8 bolt with Nylock nut. A real PITA if you do frequent changes.
That pin you picture there Newbury looks like some of my son's Chinese puzzles. I kept looking for a way to "undo" it.
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
2021 CATERPILLAR 299D3 XE SKID STEER (A60429)
2021 CATERPILLAR...
2010 BOBCAT TOOLCAT 5610 UTILITY WORK MACHINE (A59823)
2010 BOBCAT...
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
Dual Rear Wheel Axle (A59230)
Dual Rear Wheel...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
