What is this part?
   / What is this part?
Do you mean the nut on the outside of the differential or is there a nut inside also? The nut on the outside still has the cotter pin in it and appears to still be tight.
   / What is this part? #12
He is talking about the nut on the inside of the housing. Nut on the outside is just there to hold 3pt arm.
I was afraid that was the case. Looks like I need to spend a day working on it, don’t want it to wear and cause any serious issues.
   / What is this part? #14
Since I said 'go in thru the pto hole'.. you can assume that means 'inside'.
I was really hoping I read that wrong. Need to get out the manual and read up on pulling the pto shaft.
   / What is this part? #16
drain oil and 4 bolts.. not much too it.
I degreased and pressure washed it today so when I have a day I’m going to get it knocked out.
207281 (A52708)
207281 (A52708)
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56438)
2019 Krause...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
iDrive TDS-2010H...
