Cylinder for log splitter questions
   / Cylinder for log splitter questions #1
polemidis
Gold Member
Winthrop Maine
LS XG3140
I am looking for a cylinder for my log splitting part of my firewood processor, and I see a huge variance in prices, and some differences in rod diameters.
A few questions plz:
a)If a cylinder is rated for 3000 or 3500psi will last longer when I operate it at 2500psi, that one that is rated right at 2500psi? With the same use/abuse?
b)How important is the rod diameter other than the difference is retracting speed? I am looking ar surpluscenter, at 4" bore cylinders there are options for 1.75",2" and 2.5" rod diameters. The price range is not analog to that
c) Whats the catch with this cylinder? Its only $140 (rated at 3000psi) where the other cylinders 4" bore, cost $250-$300? Is it just an overstocked item? Maybe there is an mistake on the price?
d) I am trying to figure out if going to 4.5" bore cylinder make sense for splitting 16" of red oak, white ash, and some yellow birch and blask ash. How much slower will be the 4.5" with a 22gpm/7gpm 2-stage pump? A requirement is a 4way wedge.
e)Is there a way to restrict the movement of the rod to move only 15" than 24"? I dont see any shorter cylinders than 24" long.
f) I-beam, "W", would the 8x28 suffice?
thank you!
   / Cylinder for log splitter questions #2
The bigger bore will be slower as more hydraulics oil will be required.
Since you are basically pushing the shaft size is of no importance, just stronger. (On 2 way operation the larger shaft would make a difference in return speed)
My DIY splitter uses a 4" old 'dozer cylinder (LOL. $25.00) mounted on a 6" X 6" H beam (3/8" flanges) and I drive it from my tractor hydraulics (a bit slow) but then I can cut 4" maple sideways in lengths. Mind U the H beam kinda groans and twists but cuts without hesitation.
As to price, it probably is simply that it is real 'surplus' and not a replaceable stock item.
As to travel distance if U use a valve that is mechanically linked to automatically return once the split is done you don't have to worry.
(I rigged a lever and a rod that actuates the return thus freeing my hands to retrieve a new log or heave the splits onto the pile.*)
Rather than a simple knife blade to split I welded a long 'VEE' from 0 to the 6" width of my H beam (V is about 7" long) so that my logs really split wide open real fast. In my case as luck had it my local shop has a leftover section of hardened knife edge that he had from installing a new edge on a bucket.
If that cylinder is rated at 2500 it will probably do U just fine, main criteria will be to keep debris away from the seals.
Mind U I have only made this one splitter but that after studying many commercial units out there.
*( valve had a spring loading which I removed to allow my lever return system)
While splitting I do need to hold the valve open while splitting.
   / Cylinder for log splitter questions #3
I've got a 5" bore on both of my splitters. Splitting nice straight grain red oak that's a waste. Unfortunately it doesn't always pan out that way. And you say it's a processor. That implies a several way wedge. Sometimes I have to take my 4 way off to get a piece split with that. My homemade splitter has a 5" bore 22" stroke cylinder that I bought at a salvage yard for 25 cents a pound. How tall and how wide is your beam? I understood your other thread to be it's 28" wide. If you insist on using the 4" cylinder, use 2 of them. That's a little bit stronger than one 5".
no the "28" means 28pounds per foot. See the link, it has the specs. Curently I have not any beam. I am going to purchase it. I will make the CAD intending to buy everything new, but if I can find something at some scrap yard I will make any changes. I just want to have a plan with something that works first.
   / Cylinder for log splitter questions #5
Go big or quit now on the beam. That's another lesson you can learn at my expense.
   / Cylinder for log splitter questions #6
That is a "trunnion mount" cylinder, the mount on the larger part of the cylinder is with a pair of pins at the top instead of a clevis or through pin tube at the bottom. Should be fine for a splitter since you can make whatever kind of mounts you need but for someone looking for a regular cylinder mount to match an existing use then it is less valuable.
This cylinder shows you what a trunnion mount looks like (the trunnions can be mounted anywhere along the length, this one and your link both have them up near the top)
2.5x1x1.5 Double Acting Hydraulic Cylinder Trunnion | Double Acting Hydraulic Cylinders | Hydraulic Cylinders | Hydraulics | www.surpluscenter.com
   / Cylinder for log splitter questions #7
thank you!
A. Probably not. Higher pressure rating is typically thicker metal, but seals are what wear and are usually the same.
B. Bigger rod is MUCH better for a fast retract speed. But keep in mind that even with a 22gpm pump.....you are gonna want a ~40GPM valve to handle full flow.
D. For a multi-way wedge you want the 4.5 or 5" cylinder for sure
E. Look harder. You can get a cylinder in whatever diameter and length you want
F. Maybe. Depends on what size cylinder you ultimately end up with, and how you plan on attaching the wedge and cylinder. So cannot answer that question just yet
   / Cylinder for log splitter questions #8
Plating the top and bottom flange of a beam will strenghten the beam more than plating the web. To prevent the beam from twisting, it needs to be boxed.
The cyl needs to be rated for the maximum pressure you plan on running. I have seen little 2000psi rated cyl swell like a balloon when subject to regular 3000psi use. Once they balloon, there is no rebuilding or replacing seals, the metal has stretched over size and it simply wont seal anymore. Going with a higher pressure rated cyl than your machine can make is just a waste of money. A lot of things will work as far as valves and such are concerned. Some things just work better than others. Using a 25gpm rated valve with a pump rated for 25gpm will work, even tho the return stroke is pushing a lot more than 25gpm on return, but if your returning 40 gpm with your 25gpm pump, a 40gpm valve will just work better. Larger rods will return faster than a cyl with a smaller rod, and also push more gpm on the return stroke.
With limited use, it probably isnt going to hurt anything to use the 25gpm valve with a return flow of 40gpm because the 40gpm is going to be low pressure, but it is going to increase the velocity of the oil and can cause aeration of the oil and also create extra heat. This means you would really need a larger oil tank to allow the aerated oil to release the trapped air bubbles and maybe even a oil cooler to prevent over heating. Another option is to use a dump valve on the oil return to allow the returning oil to bypass the control valve. All of this is mute if your cyl has little ports. 1/2in ports on the cyl negates any other plumbing you can do. The oil has to exit the cyl before it can pass thru a dump valve or control valve. When you start hitting 40gpm flows, even 3/4 in ports are marginal. For maximum cyl speed, use a cyl with the largest rod dia and biggest ports as well as a valve that will handle your expected oil flow.
   / Cylinder for log splitter questions #9
Here's a nasty piece of sweet gum that was all my 5" cylinder wanted. Here's another nasty piece of oak through the 4 way. I later had to remove the 4 way because I couldn't push a nasty piece of hickory through it. IMG_0783.JPGIMG_0784.JPG Unless you don't actually plan on splitting anything or plan on running 4500 psi hydraulics, give up on the 4" cylinder idea.
Thank you all. Muddstoper, no intend to use anything out of specs man!
Ok, I abandon the idea of 4". probably going to 5" I
I understand the bending forces on the beam. I think that by keeping the cylinder as close to the beam as possible will limit that stress. But what about twisting? Is it a big stress? I do not get how the twist force is generated. maybe from weird knotty logs?
I believe the trunnion mount will cause less bending forces since the distance between the rods is only 3.5" right?
Thats a rough CAD of the splitter part, no much detail yet though. :)Screenshot from 2017-12-11 00-08-28.png
2022 CATERPILLAR 289D3 SKID STEER (A60429)
2022 CATERPILLAR...
Bell 1600 Gallon Nurse Trailer (A56438)
Bell 1600 Gallon...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2011 Chevrolet Silverado 2500 Pickup Truck, 127808 Miles, Utility Rack - GREAT WORK TRUCK (A56438)
2011 Chevrolet...
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
