Plywood for concrete forms
   / Plywood for concrete forms #21
You were the first person to use the word "cement". The nitpickers on this thread may point that out to you in a negative way!!! :)
Nope, my usage was absolutely correct. Concrete is a product of various aggregates and hydrated lime cement. I was giving the formula from the hydration of cement.
   / Plywood for concrete forms #22
Didn't say you weren't correct. Your statement implied that the hydration of cement was the same as the previous discussion of hydration of concrete. :)
   / Plywood for concrete forms #23
That the product is CaO.2SiO2.4H2O, which is a hydrous material
Anything is hydrous material until dry or cure.
lol...
Add a little lime and Portland to mud, and your definition works. But is that really concrete?
   / Plywood for concrete forms #24
The hydration of cement is the only hydration that takes place during the creation of concrete, so they are the same thing. The sand and rocks do not hydrate.
   / Plywood for concrete forms #25
The formula shows that the water remains and is part of the molecule that is hydrated cement. Just like mica and amphibole are hydrated minerals.
   / Plywood for concrete forms #26
I think you just made Snobdds point. :)
   / Plywood for concrete forms #27
Man, this got stupid
   / Plywood for concrete forms #31
I am not a chemist like everyone else on this spiraling out of control thread, but I put a roof on a storm shelter located in my garage. I used 3/4 treated plywood and after a little bracing I poured an 8" thick x 8'x8' slab as the roof. There was no way to get the plywood out after the fact. It has been 3 years and still looks like new. I did throw some screws into the wood to hold it to the concrete just in case it would sag in the center.
   / Plywood for concrete forms #33
It takes a lot of bracing to form a wall using plywood.
   / Plywood for concrete forms #35
After building a small number of walls using 20 sheets plywood and having to buy tons of 2x4s I found out that every piece of wood got sucked into the system anyway. A lot got reused for other concrete walls, a lot got used for shelving in the garage and barn. It all got used up someplace else so it was not all money down the drain.
   / Plywood for concrete forms #36
Yep it can be used again definitely. Also, other side of the formed wall looks the same. With lots of form ties to hold them together. Just wanted to offer OP an idea what is involved. Concrete will bulge or even knock down the form if given a chance. Better safe than sorry.
   / Plywood for concrete forms #37
Or cross ties between the walls, Forms for my patio retaining wall (6!x4'x24' consisted of 2x4 lengthwise top and bottom, a few vertical 2x4 and a lot of 'snap off' cross ties.
   / Plywood for concrete forms #38
We have a product called Formply, it is a black coated plywood designed for concrete formwork, I'm sure you would have the same thing but probably with a different name.
Have used this for various tasks not relating to concrete and the last one was for a new ramp on a horse float.
   / Plywood for concrete forms #39
Yes to snap ties. The photo I put up shows lots of snap ties connecting the walers.
   / Plywood for concrete forms #40
SnobDds is completely wrong. Rock crawler is correct, the cement hydrates in the concrete while water is incorporated in the new compound. Water does not evaporate, except the excess which is not needed in the chemical reaction
2018 Deere 323E (A53317)
2018 Deere 323E...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Crown Stand-On Electric Forklift (A59228)
Crown Stand-On...
2021 Deere 331G (A53317)
2021 Deere 331G...
43055 (A55851)
43055 (A55851)
8065 (A55852)
8065 (A55852)
