Landpride 4 in 1 bucket for BX?
   / Landpride 4 in 1 bucket for BX? #2
Most of the BX models here come with a 4 in 1, we bought ours just under a year ago and Kubota were offering $2k off the 2370 or a 4 in 1, it is not branded but I don't know where it comes from.
It makes the tractor very versatile and I use it for lifting redgum sleepers (heavy and a great place for snakes to hide) as well as pulling out old fence posts and star pickets.
Takes a bit of getting used to as you can't see the jaws but after a while you just 'know' where they are at.
I spread a lot of blue metal and this makes for a precise dump while reversing, in fact I don't know how we would have got by without it.
Hydraulics are good and has a grip like a bull terrier, it won't let go although I have dropped the odd sleeper that just wasn't gripped properly but as I said they are heavy as redgum is a very dense timber.
It is also useful for moving trailers as I can grip the hitch then lift a manoeuvre it around more precisely than our tow vehicles.
I have seen Landpride in Youtube videos and it looks like a good reputable brand, who knows we could have one but it came from the dealership and they said it was Kubota which to me means nothing.
Heavier construction than the standard bucket so should last well.
We don't take it off although it does have quick disconnect for the entire FEL or the bucket, hydraulics are quick coupling.
I'm not sure if the lever is standard on the tractor or the two buttons for the jaws only come when you get the 4 in 1.
   / Landpride 4 in 1 bucket for BX? #3
This looks like it could be a pretty useful item for my bx2370. I believe it works with either the quick tach or without. Anyone here used one of these? Thanks....
CB5 Series Combination Bucket | Land Pride
I have one. It's only available in a pin on for the bx. Biggest problem with it is it doesn't come with any kind of level indicator. An you can't see the front edge of the bucket at all. I added one to either side of the bucket when I got it home. IMG_6073.JPGIMG_5897.JPG IMG_5959.JPG
   / Landpride 4 in 1 bucket for BX? #4
I bought a 4 in 1 bucked for my L6060 when I bought it because I had regular buckets on my M9960 and my MF 2623, since sold.
To this day, I have not found a need for the 4 in 1, though it would likely be handy if grading loose dirt or stone. It can also be used to grasp logs, etc., but a grapple bucket is much more useful for such work.
SDT
   / Landpride 4 in 1 bucket for BX? #5
I have a Kubota 4n1 on my B26 and use it all the time today cleaned barn and never needed a pitch fork for that last bucket.
   / Landpride 4 in 1 bucket for BX? #6
Clearly mine comes from somewhere else after seeing the pics, I utilise the flat bar across the bucket that protects the hoses as a level indicator.
   / Landpride 4 in 1 bucket for BX? #7
I have one. It's only available in a pin on for the bx. Biggest problem with it is it doesn't come with any kind of level indicator. An you can't see the front edge of the bucket at all. I added one to either side of the bucket when I got it home. View attachment 531914View attachment 531913 View attachment 531915
I can't see the front edfe of my regular bucket on my BX. The only time I've actually been able to see the front edge of a bucket was on my Bobcat T190 skid steer loader. Is this your first tractor?
   / Landpride 4 in 1 bucket for BX? #8
Yours looks like a factory kubota bucket
   / Landpride 4 in 1 bucket for BX? #9
The dealer said it wasn't but after all the problems I had because of their incomptence it is quite possible.
Anyway, it works well (after all being sorted by a different dealer) and I am extremely happy with it, shifted two truck loads of gravel yesterday before it got too hot.
   / Landpride 4 in 1 bucket for BX? #10
I wish they had one for the LA364 loader on my B2620. I would get one. We have a 4 in 1 on our Case 580 Super M and I use it often.
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
BETTER BUILT FUEL CELL (A58214)
BETTER BUILT FUEL...
Hustler super Z zero turn (A56859)
Hustler super Z...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
