Wagtail
Super Star Member
- Joined
- Jan 15, 2013
- Messages
- 12,903
- Location
- St Helens, Tasmania, Australia
- Tractor
- JD 4105 / JD Z355E (48" deck)
My first question would be what were you using as a counterweight off of the 3PH?
Slightly OT but not really. You just learned how/why your tie rod ends wear out on vehicles. It takes a great amount of force to steer wheels that aren't rolling and especially so when you have a loader bucket full of sand (or a huge snowplow hanging off the front of your 4x4 truck). This is how I do it...rarely do I turn the steering wheel of any vehicle when it is stationary. Even a small amount of motion will put less stress on the steering system components. When I back into the turnaround in my driveway, I "pre-steer" the wheels as I'm backing into the spot. For example, I begin backing straight out of the garage and then turn my wheels to the right to back into the turnaround, before I come to a stop to go forward, I "pre-steer" the wheels to the left so they are now pointing in the direction I want to go when I shift into Drive.
I honestly believe this is how my tie rod ends can last the life of my truck but they only last 75k on my wife's car.
The wheels should be able to turn even with the bucket full.
A possibility might be there is an obstruction by the tires. I would try to move up and back a little while turning to keep the tie rods from getting stressed to much, like mcfarmall suggested. That seems to be a good idea and I practice that also if possible.
Make sure the tires are full to max air. Try to keep weight on the rear and weight prescribed by owners manual while bucketing.
May just be a case of extreme noobness, but today was the first time I had the bucket filled with 1/2" gravel. It was heavy, but not enough to lift the rear tires off the ground. When I got to the point where I wanted to drop the load, I needed to inch to the left. As I tried to turn the steering wheel, I got the wheels to change direction by maybe a couple of degrees. But without moving forward/backward, they would not change the angle any further.
Is that normal? I've never had that happen before (without load) so I'm not quite sure what to expect.
Keep tires inflated to the max and if your in soft soil sitting still with a heavy bucket there's a lot of resistance doesn't hurt to move the tractor a bit when turning.
I fully agree. The force required to turn the wheels with no movement of the tractor is tremendous. Have you ever watched a car turning the front wheels without forward/backward movement?
