How do you chain down your 50 HP tractor for transport?
   / How do you chain down your 50 HP tractor for transport? #81
Don't forget to throw a chain over the FEL or bush hog, too. Your implements need to be tied down as well. With them you can get away with a strap as long as the WLL of the strap is clearly visible on it.
You can also use cargo securement straps on the equipment provided the WLL is clearly visible on them and you don't exceed their limits.
   / How do you chain down your 50 HP tractor for transport? #82
I use ratchet straps that have chain ends on them for aux. equipment securement.
Use them to secure our John Deere Zero Turn on trailer as well.
I have seen those and they look appealing, but how does the strap hold up? Sometimes my strap goes across equipment and while it's not a sharp edge ,cwill damage the strap. Then I'm out the $$.
I have some old straps with high quality ratchet handles but bad webbing. How do I get new webbing installed on these? Seems like you would need a heck of a sewing machine. Who fixes these?
   / How do you chain down your 50 HP tractor for transport? #85
You don't 'fix' them, you replace them and use the old webbing for protection from sharp edges.
   / How do you chain down your 50 HP tractor for transport? #86
I agree. No fixing the straps. Get some good straps, heavy enough for your intended use. As noted above, my go to straps are 2” with chain ends. The chains / hooks prevent abrasion of straps where you tie down.
I buy some canvas strap protectors that go over straps and slide to any area where your strap crosses a sharp edge. Guess you could use sections of inner tube but these protectors work well and not expensive.
1 Sliding 12" Sleeves Webbing Web Protector f 2" Ratchet Tie Down Strap Cover | eBay
Wow, I did not know about strap protectors and will get some. Great idea.
It's not that I want to fix straps but I have some older ratchet handles that are super heavy duty and in perfect condition, far better than anything today. I just figured I could re-web and have a much better product? Yes? No?
   / How do you chain down your 50 HP tractor for transport? #88
Doubtful.
   / How do you chain down your 50 HP tractor for transport? #90
So I got some goodies in today and spoiler alert, I may have gone a bit too large on the D Rings lol
Those are the unbreakable shackles also, I was concerned they were gonna be too large but they are not, they will work great.
Idk about the D rings, I will either send those back or use them as a tow point or something. Sending stuff back is such a hassle lol.
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 78in Dual...
25077 (A51694)
25077 (A51694)
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2025 Swict 60in Bucket Skid Steer Attachment (A53421)
2025 Swict 60in...
