Mig porosity out of nowhere?
   / Mig porosity out of nowhere?
   / Mig porosity out of nowhere? #32
I thought than non chlorinated brake cleaner was fine.
   / Mig porosity out of nowhere? #33
I had that problem on one particular weld at the inside of a 45 degree angle and I found I had to turn the gas down to get it to stay around the weld. this was in a tight area with obstacles around it and I guess the high volume of gas was creating turbulence and not shielding properly. turned the gas down a little and the next weld turned out good.
   / Mig porosity out of nowhere? #34
That is an interesting thought/tip to try. Thanks.
   / Mig porosity out of nowhere? #35
Brake cleaner is deadly, 40 years of welding and I would've never guessed that........first I heard of it.
Also my method of removing oil off steel is 6011, but on aluminum, from this day forward if I do weld on aluminum, wont be using brake cleaner, and since 6011 is out of the question, I'll just go with sanding, heating or throwing.
   / Mig porosity out of nowhere? #36
Really just the chlorinated brake cleaner to be worried about.
I use acetone instead, works very well and is cheap.
   / Mig porosity out of nowhere? #37
I'm an Acetone fan too. Use for bare metal cleaning. But I do use brake cleaner on the tractor and on other painted surfaces to wipe/clean off grease and grime.
   / Mig porosity out of nowhere? #38
I do too, but I buy the non chlorinated kinds - fortunately for me the local brands have "chlorine free" in large print that I can read even without my glasses :)
But for welding I use acetone much more often.
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
2007 Volvo VNL Truck Tractor (A56438)
2007 Volvo VNL...
CAT 930M (A58214)
CAT 930M (A58214)
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
