Edge Tamers on my gravel drive
   / Edge Tamers on my gravel drive #71
I should have rebuilt/redesigned the abominable OEM level indicator by now :duh:, but in the meantime what I quickly learned was to lower NH's lift arms as far as they'll go and float, then creep a few feet slowly uncurling and watching for the imprint of the ETs. Once I'm 'there' I can forge ahead at will, badda bing, etc.
I can also see where I'll be getting some welding practice building up wear pads after a season or two. :laughing: They'll never see pavement, but I'm mostly making contact just at/behind my 3 3s' front bends and it'll add up ... someday.
What my blade doesn't pick up is being nicely compacted (8" or more of semi-loose powder, ~20^F), making it easy to hold lines on successive passes. I've taken off some paint, but moved barely a handful of stones vs a bushel or more/area and fighting blade angle on several long runs and clearing three 4-wide parking T's.
My d-way's crown has a fairly small radius, but I haven't gouged it yet. Clearing our driveway entrance(s) has never been so easy. I 'carved roads' around the barn in minutes w/o stirring a blade of grass. Time to do so much was easily halved and ... that'd be say 1/2 gal vs 1.
Yeah, I'm pretty torqued on the concept and obviously would recommend the branded product(s) for design/craftsmanship, ease of use/installation (for the fortunate), and o'all value. Something worth reading this far for: 'walking' your fronts back out of a snow-filled ditch with the bucket just got several times easier. :rolleyes:
   / Edge Tamers on my gravel drive #72
Just used mine for the second time today. They did a great job. I am convinced that I can push a larger mound of snow with these things on than if I did not have anything on them. Made short work of pushing the snow around.
   / Edge Tamers on my gravel drive #73
The only downside I have found is that now I cannot use the back of the FEL cutting edge to pull snow back from the front of the garage
On the flip side, I learned yesterday they work great for carrying logs!
   / Edge Tamers on my gravel drive #74
They do work well for moving logs. I also got the edge extenders because I needed to move a ton of lumber. I have not yet found the need for forks and the extenders were cheap and a good compromise for what I needed to do.
They are also great for moving a bunch of T-Posts out to the fence line to start to install them.
   / Edge Tamers on my gravel drive #75
I ordered my edge extenders last month. I could never get along without my forks, I use them 3 times as much as I do the bucket.
   / Edge Tamers on my gravel drive #76
I'm hesitant to buy these unless they work ok over the Piranha Tooth Bar. Anyone successfully using these over the PTB?
   / Edge Tamers on my gravel drive #77
The PTB comes off with two bolts, why would you leave it on for snow removal?
   / Edge Tamers on my gravel drive #79
My problem had long been a lack of precision when angling the FEL bucket to not dig into gravel when pushing snow in 'float'. My 'level indicator' was vague as all heqq, and it mattered a lot before I bolted on three ET's.
Here's a patch I 'cleared off' in 5 min or so. Note the grass 'showing thru' but not obvious in the piles. This stuff came up so 'clean' I used some to make a hill for the neighbor kids to play on, as requested.
If PTB was all that vital for snow removal, it's hard to imagine gaining much by adding ETs. You either want to 'cut' or 'clear' with the bucket edge. Need a 4-way bucket to do 'all that'? Hmmm ....
   / Edge Tamers on my gravel drive #80
Post #58 shows pics of the set I made for $35 that fits over my piranha tooth bar.
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2012 Chevrolet Impala Sedan (A55853)
2012 Chevrolet...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
2019 Toyota Rav4 LE Hybrid AWD SUV (A55853)
2019 Toyota Rav4...
Standing Metal Firepit (A55853)
Standing Metal...
2018 John Deere 30G Mini Excavator (A52377)
2018 John Deere...
