shui5612
- Joined
- Jun 24, 2014
- Messages
- 127
- Location
- Montreal
- Tractor
- 2013 Yanmar SC2450, 2008 Kubota ZD326, 1986 Deutz 7085
If you're wanting to maintain 55-60F in your garage throughout the week then it's a good alternative, assuming your insulation is good and you won't be heating the outside.
In this case I would install two 4500w units, one on the wall type that circulates air by pushing it towards the garage door and a second that is on the ceiling and pushes hot air down. Set the ceiling one at the desired temperature and the other abit higher by a degree so it kicks in less frequently.
The point is to have two different airflow circuits so that you get heat evenly throughout the garage and the ceiling mounted one helps push the hot air back down. The wall mounted type pushes air in a certain direction to create circulation since they are far better at pushing air than the ceiling type but can cause too much circulation which prematurely turns off the heater, leaving most of the heat building up at the top.
How high are your ceilings?
