New Farm and Need a Tractor..
   / New Farm and Need a Tractor.. #1
chaded
Member
SE Ohio
None
Hey guys, my wife and I just bought a farm back in October and I am going to be needing a tractor. The previous owner had two tractors and left one for his dad which is a real close neighbor (has a little lot carved out of my property) and he gave me a key to it and I use whenever but I would like to get my own.
We have 257 acres. I have a 30 acre hayfield and i have a pasture (so beef related tasks). My driveway is very long and uphill and needs to be plowed. I also burn wood for heat so I will need it for trees and whatnot. I will also put food plots in and do some bush-hogging. The property is in southeast ohio and is really hilly.
Dealers close to me are Massey Ferguson, John Deere, and New Holland so I would like to keep it to those three. I would like to keep price around 30-45k and get something used? I was hoping you guys could get me going on the right track with which models I should be looking at.
Thanks!
   / New Farm and Need a Tractor.. #2
Welcome to TBN!
Will you be baling hay or needing to lift/carry round bales?
You're gonna be busy with your tractor so I'd get a nice one, and definitely with a cab.
Many of New Holland tractors are made by LS. You can buy a LS for quite a bit cheaper and they're great tractors. There's a dealer in Bremen, Foltz Ag and Diesel service is thats close to you.
I would want a 50+hp tractor. Maybe a LS XR4155C unless you're gonna be haying. Then a LS XU model. There's lots of other great tractors though from Kubota like a MX, or a 5 series JD.
   / New Farm and Need a Tractor.. #3
When it come's to which brand is best,flipping a coin or asking your barber beat's asking on a public forum. Asking which brand used is three times as problematic. If the neighbor was kind enough to lend his tractor,he will be happy to help chose a tractor to suit your needs. Point is that judging used cars and tractors is an art that take's years of experience and can't be taught through posts on the net. I use those in my sig,if I thought there were better choices I would have bought them instead.
Welcome to TBN!
Thanks, gersus. I will eventually need the tractor to bail and lift bails. As far as the LS, I have looked a little bit and there’s nothing close as far as i know.
I’m not asking which brand is best or which brand used. I gave the three brands to choose from because that is the only thing I know of close that I might have support if I need it? The previous owner has a new JD Deere 5100e that he barely even used and a Massey 243 (that im/his dad) uses.
I get your point though and I do have someone experienced with tractors I plan to talk to and hopefully get to take with me. Just thought i would get some reccomendations from here on some models to look for, assuming they are in good condition.
   / New Farm and Need a Tractor.. #6
My wife and I bought a farm in October. Therefore, I need a tractor.
Tell us the brand and model of the tractor you access and how it meets your perceived needs. Does it have a Loader? Is it 4-WD?
Give us some detail what is growing on the balance of your your 257 acres, beside the 30 acre hay field.
   / New Farm and Need a Tractor.. #7
Massey Ferguson 243
1999 - 2003 200 Three Series
Utility tractor
Manufacturer: Massey Ferguson
Factory: Coventry, England
Original price (USD): $20,050 (2003)
Massey Ferguson 243 Engine:
Perkins 2.7L 3-cyl diesel
full engine details ...
Capacity:
Fuel: 12.7 gal [48.1 L]
Hydraulic system: 8.5 gal [32.2 L]
3-Point Hitch:
Rear Type: II/I
Power Take-off (PTO):
Rear PTO: live (two-stage clutch)
independent (optional)
Rear RPM: 540
Dimensions & Tires:
2WD Wheelbase: 75.1 inches [190 cm]
4WD Wheelbase: 76.1 inches [193 cm]
Weight: 5045 to 5130 pounds
Front tire: 6.00-16
Rear tire: 13.6-28
Massey Ferguson 243 Power:
Engine: 52 hp [38.8 kW]
PTO (claimed): 47 hp [35.0 kW]
Drawbar (tested): 37.7 hp [28.1 kW]
PTO (tested): 47.6 hp [35.5 kW]
Mechanical:
Chassis: 4x2 2WD
4x4 MFWD 4WD
Steering: hydrostatic power
Brakes: independent wet disc
Cab: Two-post folding ROPS.
Hydraulics:
Capacity: 8.5 gal [32.2 L]
Pump flow: 9.5 gpm [36.0 lpm]
13.9 gpm [52.6 lpm] (optional)
Total flow: 9.5 gpm [36.0 lpm]
13.9 gpm [52.6 lpm] optional
160 something is woodland (mostly big hardwoods), pasture, hayfield, some other open areas that I will put i to food plots (clover, turnips, etc.)
Massey Ferguson 243
Utility tractor
Capacity:
3-Point Hitch:
Rear Type: II/I
Rear RPM: 540
Dimensions & Tires:
Front tire: 6.00-16
Rear tire: 13.6-28
Mechanical:
Chassis: 4x2 2WD
4x4 MFWD 4WD
Hydraulics:
The Massey 243 was/is not used here for all the things I will be. I’m not saying it’s not capable but they didn’t use it for all of that. Someone else did the hay and they didnt move heavy trees around. I was thinking something bigger?
   / New Farm and Need a Tractor.. #10
Tell us how the MF 243 you use meets your perceived needs.
LOT: Fuel Transfer Tank, Tool Box, 12 Volt GPI Pump (A59076)
LOT: Fuel Transfer...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2019 GALYEAN...
2009 Ford F-150 Ext. Cab Pickup Truck (A55973)
2009 Ford F-150...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
