Cheap Start to Reloading?
   / Cheap Start to Reloading?
So, I ordered the Lee C-Clamp press ($32.09), Hornady American 3-Die set ($34, but you get 100 free bullets with mail in rebate), WAOAW digital scale ($19.99), Hornady funnel ($3.47), Lee Powder scoops ($10.99). Still need powder (Hs-6, CFE pistol, Universal; depending on what's in stock), Primers, projectiles, Lube ...
I'll be right at $150, with 1 pound of powder, 200 projectiles, reusing by Blazer Brass,
I went 9mm Para, even though I know the savings won't be there. More as a first step, see if I'm going to actually enjoy it, then next would be 7.62x39 and 6.5 Grendel.
I will start by using .40 cal brass brush and small scraper to clean brass... and may upgrade to vibratory tumbler in the future.
I do get everyone's point that was saying, buy once buy good equipment and not have to buy later. The issue is if I'm going to be in this $500 to start with I won't ever be in it to start with. If I do end up really enjoying it and upgrading later I can always use the press as a dedicated depriming station or something of the like. I was kind of torn on the Hornady dies because they're not carbide there some sort of nitrated titanium but I went that direction just to get the hundred free bullets
   / Cheap Start to Reloading? #43
I started for only one caliber, with a Lee loader. The type you hit with a hammer, no press involved.
Currently using a hand press (it will easily FL resize 7.62-51 machine gun brass and will pull the rim off if you don't lube it.)
The Lee perfect powder measure is a fantastic upgrade over scoops once you have a load you want to make a bunch of.
If you have a friend with a stainless steel pin tumbling cleaner, ask nicely and you will probably get really clean brass.
Casting lead and sizing bullets is another skill to learn.
Picked up 1 pound of CFE Pistol ($23.99) and 100 Hornady XTP ($19.99) from Acedemy. They had no small pistol primers at Academy, so I picked up 100 CCI 500 small pistol primers from a local gift and gun shop for $4.29.
Note: I forgot the Ram Prime set up when ordering online, so I'll be about $12-15 over budget.
So, last night I loaded up 20 rounds of 9mm. 4.9 gr of CFE Pistol (Hodgodons starting charge) with 124 gr Hornady XTPs. Each charge weighed. 100% function. Accuracy, 2" circle at 15 yards, don't know how good that is, but it's 9mm...
Cases where heavily smoked, so I think I'll probably move up a bit, but stay well clear of 5.5 gr max.
   / Cheap Start to Reloading? #48
I started out with a Dillon Precision 550B progressive way back in 1986. I load or have loaded: 9mm, .40 S&W, .44 Mag, .223, .308, 7mm-08, .303, 30-06, 45-70 and probably one or two more calibers I don't recall at the moment. I just ordered a caliber conversion from Dillon for the .45 ACP.
I recommend progressive for a number of reasons:
- Far easier to learn the various steps without the constant need to tear down the press for the next step; once you have one operation/stage adjusted right, you don't have to tear it down for the next stage.
- Most progressive presses can be used as a multi-single stage press. In others words, you do one operation at a time, but after 4 (or 5) cycles of the machine, you have on completed round. You can see all four (or five) stages with one round. Single stage presses are just that: Do one operation a hundred times, tear down, reassemble, do another operation a hundred times, tear down and so on and so forth.
Dillon is the gold standard of progressive presses. Yes, it will cost you, buy once, cry once.
Good luck.
   / Cheap Start to Reloading? #49
- Most progressive presses can be used as a multi-single stage press. In others words, you do one opearion at a time, but after 4 (or 5) cycles of the machine, you have on completed round. You can see all four (or five) stages with one round. Single stage presses are just that: Do one operation a hundred times, tear down, reassemble, do another operation a hundred times, tear down and so on and so forth.
Good luck.
Yep.
To the OP, next up in a chronograph or find a buddy with one. Test those puppies to find out what you have crafted. :)
   / Cheap Start to Reloading? #50
Dillon 550 is on my wish list. I have had years of reloading on a single stage Rock Chucker, but would like to set up progressive for 45acp and 357mag. I have family member with a 650; that thing is sweet!
The OP however, was trying to get started for $150. If you know of a complete RL550B for $150, please post; I'll buy it!
I'm seeing RL550C for $450-550 set up for one caliber. That is 3x the OP $150.
Good luck.
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
2013 Ford F-150 (A50397)
2013 Ford F-150...
2018 INTERNATIONAL LT625 SLEEPER (A51219)
2018 INTERNATIONAL...
2013 HINO 388 (A50854)
2017 Makita HM1307CB 35lb Demolition Hammer (A49461)
2017 Makita...
