How long should Hydraulic seals last? Bradco a fail?
/ How long should Hydraulic seals last? Bradco a fail? #1
simmysam3
Spokane, WA
TYM 330 HST
How long should hydraulic seals last?
I have a bradco 3265 3-point backhoe. Had it about 7-8 years, probably less than 300 hours with it actually mounted. Relatively light use, a couple of long trenches, planting some trees etc.
I just had the 3rd cylinder rebuilt, and the fourth is on its way... for the stabilizer leg no less which should be pretty low wear.
This on top of the boom that falls too quick, can't say I would recommend a bradco, what a piece of crap.
/ How long should Hydraulic seals last? Bradco a fail? #2
Is there any chrome plating flaking off the rams? Otherwise the seals should last a long time. Seals aren’t that expensive. Things could be worse.
/ How long should Hydraulic seals last? Bradco a fail? #3
You’re boom issue is likely caused by a crappy valve. I’m not trying to start a fight but the Kubota loader valves are the best I’ve used and the Mahindra are the worst. The only Kioti valve I’ve used was also smooth and multi functioned good. The 3 JD valves I’ve used didn’t multi function good.
/ How long should Hydraulic seals last? Bradco a fail? #4
It is not the Bradco part of it so much, it is that they use cheap hydraulic cylinders and cylinders that leak oil out of their seals.
I got a brand new attachment that leaked oil out of its main hydraulic cylinder.
/ How long should Hydraulic seals last? Bradco a fail? #5
What was wrong with the seals in the cylinders that you felt they needed rebuilt?
What was your diagnostic / troubleshooting method to arrive at the conclusion that the cylinders were a problem in the first place?
Did you ever look into that control valve as suggested several times in the other thread?
/ How long should Hydraulic seals last? Bradco a fail? #6
Kubota loader valves may be great, but their rear valves suck. My previous L3200 & current L4060 loader arms don't budge an inch in a week. After replacing the rear valves on my L4060 the TnT leaks down in an hour. Need to take it in again & have them replace them again (still under warranty).
/ How long should Hydraulic seals last? Bradco a fail? #7
Sam, I don't have any real good answers, but it sounds like you are also wanting to know whether what you are seeing is normal or not. I can compare to what I've seen if that will help.
BTW, you say that the cylinders need rebuilding but I missedwhy? What is wrong with them? Falling too fast could be internal to the cylinder but is usually the control valve. I wish I could tell you how to tell the difference, but I've never figured it out. I tend to believe that for a cylinder to fail internally so it would pretty much have to be defective from the beginning - but I think that as control valves age their check valves tend to leak. In my experience it is rare for a cylinder to leak where the extension rod moves in and out unless it has lots of damage there.
As to how long cylinders last, I've only ever had two show a problem. One was on our new Kubota when a cylinder just locked up & wouldn't retract. Warranty replaced it. I suspect it was assembled improperly inside.
The other was the JD310 backhoe main boom cylinder which started to squeak @ 6000 hrs. Disassembly showed it needed new internal O rings. The old ones were packed tight with a real fine particle muddy dust - most likely dust from the clay dust in the air. That lind of dust is common to some western dryland wheat fields.
So far I've never had a cylinder that leaked at the rod cap - even though some of my equipment is pretty old. It used to be common for all the better quality loader cylinders to have threaded end caps with adjustable packing to keep dirt away from the rod seal. That extra dirt seal was a nice touch and should have made the seals last much longer, but my experience is that cylinder rod seals last a surprisingly long time anyway - decades for sure. The few I've looked at had a wiper seal and an oil seal inside that. Not surprising that they last. A few times a season I wipe the mud off of the cylinder rods with an oil-soaked rag and inspect them for dings which get smoothed with a pocket stone.
When an implement leaks down overnight, that might be in the control valve or the cylinder either one. Like I said, I'm not sure how to tell which one is causing the problem.
The Kubota isn't perfect; at 1000 hrs my loader will fall down and the backhoe bucket will eventually unfold toward the ground if I leave them up. But it takes several days for the loader to move perceptively down and several weeks for the hoe bucket. Leakdown must have something to do with wear because when it was brand new neither one would leakdown at all.
About control valves, I didn't know that loader/backhoe control valves had such a range of quality until we got the Kubota. It has control valves that are just better than any other I've ever used on any machine. Light touch, accurate metering, smooth predictable multifunction, no leakdown. Really Nice.
There's a local hydraulic shop that serves the ag trade & will make good quality custom cylinders for same or less than the cost of new ones. Better prices on hoses and cylinder rebuilds than the dealer, too.
Good luck,
rScotty
Thanks for all the responses it verifies what I was looking for - what is normal wear life for a seal.
To clarify - my rods are absolutely clean and shiny, however it is the seal at the rod end that is leaking. By leaking I mean significantly - not a drip here and there but a flow that demanded the backhoe be removed immediately for fear of draining the system.
While the seals aren't expensive, but I have been around $200 a shot for the local hydraulic shop to replace them.
So if it is not unusual for valves to go 6000 hours, thats more than 10X over what I am seeing. I would lean toward the prior @brokentrack comment that they are probably crap cylinders/seals that bradco is using.
The prior issue of the boom dropping is likely a control valve issue, that cylinder has shown no signs of issue from a leaking perspective. I am going to take it in to the shop and have that looked at when I feel like dealing with that PITA.
Sam
/ How long should Hydraulic seals last? Bradco a fail? #9
Sam
In that case I believe you have it right.
Bradco - at least the cylinders - are crap.​
/ How long should Hydraulic seals last? Bradco a fail? #10
I have seen cyl that last for years under heavy use, and never leak a drop. Build quality is certainly an issue. I bought a new 5in bore cyl from Northern to put on my wood splitter. The cyl had 3/4 ports, but inside the port was a itty bitty 3/8 size hole. I took the cyl apart so I could drill out those little holes and the cyl was full of metal pieces and scrap. This was a new unused cyl. If I had just hooked it up to my splitter, it would have ruint my hydraulic system and I would have never knew where that metal came from. I know nothing about Bradco equipment, but if they are using cheap china made cylinders, I would be very suspect of the quality of those parts.
/ How long should Hydraulic seals last? Bradco a fail? #11
Two factors for premature seal failure is poor fit or poor finish. Poor finish could be obvious damage on the rod or rust/machine marks in the gland/piston under the seal groove. And poor fit could be too much tolerance between metal parts (sloppy housing) or grooves not machined to proper specs. This all is assuming proper seals and installation/lubrication techniques are followed during a rebuild.
I rebuild cylinders everyday, large and small, most problems we see from premature seal failure is from customers just stuffing seals in grooves and calling it good without spin polishing, inspecting, measuring, cleaning and lubing parts before the seals go in.
If parts are loose tighten them up and give a good polish.
/ How long should Hydraulic seals last? Bradco a fail? #12
Sam
I sure understand the frustration, a part of it was that machinery designers were caught off guard several times in the last 20 years. Not just Bradco. Basically the designers here were so used to getting good subassemblies and parts all built to US & European standards that we had gotten complacent. That is particularly true of the really basic things like nuts & bolts, seals, springs, lubes, and even alloys - especially stainless. It just didn't occur to designers & parts buyers that there were now a lot of new international suppliers who would take advantage of the fact that we were assuming that things were as good as they used to be without testing to see if that were true.
In hindsight, we had gotten too used to there being an implied quality of basic manufactured components that we didn't check. The assumption was that quality was standard & cost was everything. Everyone in the industry got bit by that for awhile. Most are wiser now.
It sounds like the problem in your cylinders is basically poor quality seals. The good news is you can still buy good seals. With luck, the tubes and rods are OK. If it were me I'd replace all the seals in all the cylinders - seals tend to be standard dimension parts - check McMaster Carr and any seal handbook. Good seals should then last a lifetime.
Good luck, rScotty
Just be glad it's a tractor implement and not a rocket ship.
/ How long should Hydraulic seals last? Bradco a fail? #13
Not sure if this helps, but have a Bradco 408N subframe mounted backhoe got it in 2005 it was used, came off a Bobcat skidsteer have no idea how many hours on hoe before I got it.
Mounted on a new Kubota GL3130 cannot begin to estimate hours, but tractor is at 998 right now and maybe use it a quarter of the time so maybe 200-300 hour range. If I do not lock the main boom up it would take several days to settle down. When I first got the hoe the stabilizers would drift down over a few weeks but have very little leak down on anything now, blew one hose on the dipper cylinder so replaced both on that cylinder. Changed hydraulic fluid and filter at 50 hours and 450 hours and getting ready again at 1000. Trying to think what would make the seals fail early, fluid, contamination, filter quality? Have been told by many people that the Bradco products are near the top, have forks and grapples from them also with no problems
As far as seals a lot of guys around here go to Christopher Seals in Eugene, Oregon, they do not have a web site but are in the phone directory and say they can get many seal sizes.
David
/ How long should Hydraulic seals last? Bradco a fail? #14
I have a 19year old Bradco backhoe attachment that has zero leaks.
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
(1) KENMORE REFRIGERATOR (1) FRIGIDAIRE STOVE (A60432)
(1) KENMORE...
BUNDLE OF 8'-13' CORRUGATED METAL SHEETS (A60432)
BUNDLE OF 8'-13'...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
2 ROW CULTIVATOR (A60430)
2 ROW CULTIVATOR...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
