Box Blade or Land Plane - for this dirt road type? Other?
   / Box Blade or Land Plane - for this dirt road type? Other? #1
frogracer
Sealy/Columbus, TX
NH T4.120 - ArmstrongAg Grapple, Pallet Fork
Looking for your thoughts on which tool would be best for maintaining the driveway/road type in the photos below - It's about 800' long.
The red dirt / rock mix is made up of both fines and some larger rocks some up to about 2-3" diameter.
Appreciate your feedback as I am in the market for one or the other attachments to maintain the road.
   / Box Blade or Land Plane - for this dirt road type? Other? #2
My vote....Land plane with rippers...for sure
   / Box Blade or Land Plane - for this dirt road type? Other? #3
I own both. My experience has been on gravel, the land plane is best; on soil / dirt, the box blade can't be beat. :2cents:
   / Box Blade or Land Plane - for this dirt road type? Other? #4
Land plane grading scraper if you are simply smoothing out a road. Box blade if you need to move material from here to there. I would definitely recommend that your first purchase be a land plane grading scraper. Almost zero time on learning curve and it will surprise you - how good a job it does.
With either of these two land engagement implements I strongly recommend purchase of a hydraulic top link. Jobs are so much easier, almost eliminates frustration and you will finally use the implement in its perfect alignment. I finally bought a hyd top link - after thirty years without. Being able to make finite adjustments to ANY land engagement implement - on-the-go - is priceless. Stopping, dismount, twist, twist, twist - never getting it quite right, again, again, again - - - a far distant memory of the past.
   / Box Blade or Land Plane - for this dirt road type? Other? #5
View attachment 537042View attachment 537043View attachment 537044View attachment 537045
NEITHER ONE!
You need a rear blade,.... preferably with a tail wheel!
A box blade is primarily for moving material from one point to another, and cannot be angled.
A land plane will give you a nice even surface that will be flat,..... and water will puddle (as in your pix).
You need a CROWN on that driveway, and ditches on Both sides.
You have a nice water catchment area on one side, but almost none on the other.
Think...CROWN...CROWN...CROWN.....!!!
ONLY a blade can give you (and maintain), the crown that you need!
You will need to develop some experience using a blade, but you will get/maintain the VERY best end result!
   / Box Blade or Land Plane - for this dirt road type? Other? #6
NEITHER ONE!
That is the choice I would make.
   / Box Blade or Land Plane - for this dirt road type? Other? #7
I will agree - a heavy rear blade on that tractor of the OP's can be a very good and universal implement. The other fact - efficient use of a rear blade has a MUCH longer learning curve and can make a new, inexperienced operator pretty darn frustrated. If a heavy duty rear blade is purchased - then the hydraulic top link becomes even more important. I say hydraulic top link rather than rear tail wheel because the top link can be used on most any ground engagement implement. Tail wheel is a one implement addition.
Weight is your friend if using a rear blade. I have a Rhino 950 - 8' - 1000#. I would recommend a blade this size or the next step up - Rhino 1540 - 8' - 1750#. Be prepared for $$$ shock............
   / Box Blade or Land Plane - for this dirt road type? Other? #8
I agree on a rear blade for getting your road built. I’ve got a Land Pride RB3796 that I can run on my 55 HP and my 96 HP tractors.
You could easily run a heavier RBT 45xx Series Blade on your tractor.
RBT45 Series Rear Blades | Land Pride
Hydraulic top link is almost a must have. Look at Fit-Rite Hydraulics for Top and side links.
Fit Rite Hydraulics - fitritehydraulics.com
Gauge wheels are ok, but IMHO, skid shoes are simpler and way less cost.
Once you get your road constructed, a land plane will be excellent for maintenance of it.
Wow - sounds like one day all three items will need to rented/borrowed or purchased. Please keep your comments coming as I am weighing my opitons...
Thank You!
   / Box Blade or Land Plane - for this dirt road type? Other? #10
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
8" & 10" I BEAMS & 6" & 8" CHANNEL IRON UP TO 25' (A51247)
8" & 10" I BEAMS &...
CASE IH 1083 - 8R CORN HEAD (A51247)
CASE IH 1083 - 8R...
UNUSED FUTURE FT36CJ STAND ON SKID STEER (A51247)
UNUSED FUTURE...
2012 Seal Rite SR 1000, Tandem Axel Trailer  (A52384)
2012 Seal Rite SR...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
