Saw won't stay running......Stihl MS290
   / Saw won't stay running......Stihl MS290 #1
Ville Platte, LA
John Deere 870
Hi everyone, I have a Stihl MS290, it's maybe 5-6 years old and has not seen a lot of use.
Lately it's been giving me an issue that has me stumped. First off, I have cleaned the carb out completely and have adjusted the carb as well as I can, so a clean carb is not the issue, I think.
Like a typical 290, it will take a few pulls to start. It will run for about 5 minutes, and will cut well, but then it will start choking and die.
After that, it will crank up again but when I put a load in it, it sputters and dies. I have also cleaned out the fuel pickup with clean gas and compressed air.
Can anyone help?
LC
   / Saw won't stay running......Stihl MS290 #2
Chainsaws used infrequently should be stored with all fuel run out.
Did you dump the old fuel and replace with fresh fuel?
I would install a new spark plug next.
Fuel is fresh, spark plug was clean, I am pretty sure it was giving good spark. If it was bad, I don't think it would run with power at all.
   / Saw won't stay running......Stihl MS290 #5
If that model saw has an impulse line it would be my first thought after the fuel line itself...
   / Saw won't stay running......Stihl MS290 #7
When it starts to run rough, does pulling the choke out a little bit help it run better?
   / Saw won't stay running......Stihl MS290 #9
When it quits, open the fuel cap and close it. If it starts back up, it's the vent.
   / Saw won't stay running......Stihl MS290 #10
I worked on a neighbor's 2 cycle weedeater once and the screws that held the two halves of the two halves of the crankcase had loosened up a little, so it would run OK with the choke on (it was sucking in air through the crack between the case halves and that would lean out the mixture). Once I tightened up the crank case bolts, it ran pretty well again.
   / Saw won't stay running......Stihl MS290 #11
I don't think that works all that well. I'd replace the fuel filter.
For the carb adjustment it's best to start at the factory recommended starting point, usually about 1 turn out on non limited screws. The saw should run at those settings if there's nothing else wrong. If you're way off of the factory settings on an unmodified saw to get it to run there's something wrong.
It sure sounds like a fuel flow problem. Which could be (as already suggested) the tank vent or impulse line. Also the diaphram in the carb could be damaged, a valve damaged, or a passage plugged. Saw carbs internals are tiny and easily damaged.
   / Saw won't stay running......Stihl MS290 #12
A new carb can be bought from Ebay for about $20. Chinese knock offs but work like the brand names. I usually keep a spare carb for each saw, (I have 4), and swap out if I have problems. You can buy impulse line kits and all the other replaceable parts cheap, from Ebay as well.
I took a saw to a dealer once and got skinned on the work done and price charged. I learned the hard way. They messed up other parts to fix what was really broken. There is no way I would ever take a saw or weedeater to a dealer to fix. They most likely order carbs for less than $20 and charge $100.
   / Saw won't stay running......Stihl MS290 #13
I guarantee the problem is either compression, fuel, spark or air. :D
The problem is usually not enough of one of the first 3 or too much of the last.
If it runs for a few minutes, then goes wacky, don't overlook checking the compression.
   / Saw won't stay running......Stihl MS290 #14
Pull the muffler and inspect to be sure its clean and clear. I had a similar issue which turned out to be mud daubers in the muffler.
   / Saw won't stay running......Stihl MS290 #15
FWIW...The impulse line is what controls the diaphragm in the carb...if there is a slight crack in the impulse line the diaphragm will not pump any fuel.
I have a MS 390 and it was acting similar to what the OP described...the impulse line gets warm and also has a sharp bend...there were some fine cracks at the bend...
Requires some dismantling and removing the carb. but is a simple repair for the mechanically inclined... positioning the new line onto the inner barb fitting requires a bit of fineness...long nose forceps help...
Thanks for the help, everyone. Looks like I will have some things to do this weekend.
   / Saw won't stay running......Stihl MS290 #17
First thing I would do is to open the high speed jet about 1/8 turn and see if that helps. Sounds like it is looking for more fuel when it heats up. Also, when you cleaned the carb, did you use a rebuild kit and clean out the low speed orifices under the metal cover (replacement cover comes in the rebuild kit, which is a more complete parts kit than the gasket kit)? Run fine wires through every hole and opening in the carb when cleaning?
I didn't have a kit at the time. Looking on Amazon, I see kits made by HIPA that include all the fuel lines, an air filter and the carburetor for just over $20. Anyone familiar with these? Decent quality?
   / Saw won't stay running......Stihl MS290 #19
I haven't had the best results with the aftermarket carbs. Put three of them on a mantis tiller last year before I found one that worked for more than an hour.
   / Saw won't stay running......Stihl MS290 #20
This is good advice, so many saws run different when they warm up a bit. I always tweak my carb tune for a warm saw. If you tuned it stone cold, it is probably off a bit.
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
iDrive TDS-2010H...
CAT D8 (A58214)
CAT D8 (A58214)
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
2017 Chevrolet Tahoe, 179,380 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2017 Chevrolet...
