What eye protection is best with Plasma Cutter
   / What eye protection is best with Plasma Cutter #21
What type of respirator do you use with plasma?
Because I work in both metal and wood, and then paint / finish the projects I've built - I use one style of respirator for that work. It's a standard 3M dual-cartridge type with organic vapor cartridges. I use dust/particle pre-filters at the front of the organic vapor cartridges.
I can use the same respirator for painting using standard paints, wood finishes, lacquers, vinyl coatings, and polymer coatings. The only time I change respirators is when I use two-part, catalyzed paint systems.
When I paint using catalyzed products containing isocyanates I use a different respirator. It is a full face mask, dual cartridge respirator that has 3M 6051 and 5925 filters rated for short periods of use with isocyanates. I paint outdoors with catalyzed paints as I don't have a paint booth or a fresh air delivery system. I time the amount of painting exposure to products with isocyanates, and the filters are changed after 60 minutes of use.
   / What eye protection is best with Plasma Cutter #22
Very interesting that there is a respirator for limited use with isocyanates. That's good news because I could never paint iso's since I did not have a supplied air system. That mask and filter are on my shopping list. I paint outside so that should work fine. Thanks for the tip.
EDIT--I just confirmed this with 3M . Your numbers are from Australia/New Zealand. The US number for the filter is 60921 and no prefilter is called for but I might put one on anyway. Change frequently.
3M; Pesticide/Organic Vapor P1 Filter Cartridges | GEMPLER'S
   / What eye protection is best with Plasma Cutter #23
Interesting. I purchased the filters on-line, and I don't remember the vendor. I got the numbers I provided in my post from the filter boxes in my equipment cabinet. I've copied down the number you've provided for future reference. Thanks for the additional information.
   / What eye protection is best with Plasma Cutter #24
This really is big news since using a respirator with iso's was a no-no and the only way to paint was with supplied air. Now, with the 3M filters and painting outside I can now use a hardener to really get a great finish.
   / What eye protection is best with Plasma Cutter #25
Don't know about a respirator, I've never used one. Yeah fab and welding work isn't clean and probably not good to breath. What I can tell you is WATCH YOUR EYES. Where at least protection with a 5 rating or stronger. A plasma cutter can give you "flash burn" just like a welder. Been there, done that, and got the doctor bill to prove it. Good luck to everyone on the endeavors and stay safe.
   / What eye protection is best with Plasma Cutter #26
Let me ask a question. I also have some shade 5 glasses from a high class welding shop that I never got around to using but don't have the packaging to say if they are UV protected as well as the shade 5. Are most shade 5 welding glasses UV protected as well?
   / What eye protection is best with Plasma Cutter #27
Is there a name on them, that you can search for the info?
Recently watched a youtube vid of an interesting test; 2 (typical) full-face auto-dark helmets, where it was shown that even when not triggered to go dark, they still provide 100% UV block. I never thought about that before, but good to know.
   / What eye protection is best with Plasma Cutter #28
shade 5 goggles or glasses are fine for any plasma cutting at power levels a home user would do. hobart makes some nice safety glass style shade 5's that seal against your face so things can't come in from the side. they are about $12 on amazon. goggles work too, if im going to be doing a ton of cutting, i just put a shade 5 lens in my old pipeliner style flip down hood.
   / What eye protection is best with Plasma Cutter #29
Good thinking. I checked and they are UV protected. Nemesis glasses.
Jackson Nemesis Safety Spectacle - Shade 5 Lens 25671
I use these under a face shield or simple cutting and for plasma serious I use a full shield with shade five as JGriffin suggests below. That really is the best option for most of us. Plasma cutting is dangerous and I have has sparks fly everywhere they shouldn't.
   / What eye protection is best with Plasma Cutter #30
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
2018 Dorsey Dominator 55-Ton Low Boy Trailer, VIN: 5JYLB5537JPD06956, Honda Gas Engine, Electric (A59076)
2018 Dorsey...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
