Loader BX6315 Quick Attach on BX24/25 and 50 series
   / BX6315 Quick Attach on BX24/25 and 50 series #1
Tractor Nut
Member
Manitoba, Canada
2007 BX24
There is some good discussion going aback awhile regarding the use of the Kubota quick attach(BX6315) on some of the older BXs using loaders without the A suffix on the model number. In my case I have an LA240 on a BX24.
Some of you have been using the Kubota Quick Attach for some time now on the 50 series or BX24/25s and it would be good to know if you have encounter any issues. I am looking at getting one and any info would be helpful.
   / BX6315 Quick Attach on BX24/25 and 50 series #2
Tractor Nut, I'll hop in here. I use Jery Dunn's QA on my current BX2670, had one on my last B2620, and prior BX2660. Do a search. Jery's are the schiznit. They have an incorporated 2" receiver, and flip latches to lock on the attachments. Quality is second to none. Call him up, and he'll fit you up with the right QA and ship it out.
   / BX6315 Quick Attach on BX24/25 and 50 series #3
I will second the endorsement for Jery's QA. I love it as well as the moveable forks. Great set up for the BX. One thing I do now though is use an old screwdriver to 'flip' the locking latches. Saves your thumbs from having to push hard to overcome the springs. Great quality! I routinely and quickly change from my bucket to forks because of how easy it is to do.
   / BX6315 Quick Attach on BX24/25 and 50 series #4
Great thought on the screwdriver.
I agree on JERY's QA. If I go to the 80-Series, I may see if Jery can hook me up over the SSQA. That's how much better his QA is to me. If one does not have use for other SSQA items, and the loss of weight from the SSQA can be overcome by Jery.
To the OP, Jery's QA has several benefits, and the operation and quality for the few bucks more, really will shine over the years of use over the OEM.
Thanks for the info and comments. It looks a great QA.
I have also come across the Quick Attach by Ai2/bxattachments, has anyone had experience with that one?
Unverferth 25' Head Cart (A59814)
Unverferth 25'...
SET OF 60" SKID STEER QUICK ATTACH PALLET FORKS (A58375)
SET OF 60" SKID...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2017 Ford F-550 Chipper Truck (A56858)
2017 Ford F-550...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
