Has anyone tried the Titan 4 in 1 bucket?
   / Has anyone tried the Titan 4 in 1 bucket? #11
   / Has anyone tried the Titan 4 in 1 bucket? #12
I think he does not want to mix two different oil types together:confused3:
Oh, yeah, you are probably right. Sorry I missed that. :eek:
What's the oil have to do with it??
Different brands of tractors require different hydraulic oil specifications. The bucket has 2 hyd cylinders that contain oil from whatever tractor you use it on and will dilute whatever tractor you use it on next. Kubota super UDT and SAE15w-140 are not the same, that is the 2 types of oil used in the different tractor hydraulics.
Oh, I see you got your own answer on the oil, I was responding as I went down the list.
   / Has anyone tried the Titan 4 in 1 bucket? #16
Dilution just happens. For example if you put new oil in your tractor, then hook up to an implement you have, you just diluted the product.
   / Has anyone tried the Titan 4 in 1 bucket? #17
Too bad they can't all use the same oil.
I try very hard around here, to NOT mix oils...
Last time I put a loader on that had old oil in it, I ran clean oil through it before hooking up the last hose and I've done it with implements too...
One thing about having gear drive tractors that I have, I can run the same oil in all of them...
SR
CFG Industrial MH12RX (A53316)
CFG Industrial...
2004 FREIGHTLINER FL70 FLATBED W/TANK & DITCH WITCH MIXER (A55745)
2004 FREIGHTLINER...
2014 CATERPILLAR 289D SKID STEER (A52706)
2014 CATERPILLAR...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
CAT D3B (A53314)
CAT D3B (A53314)
2005 Chrysler Town and Country Limited Van (A55853)
2005 Chrysler Town...
