Has anyone tried the Titan 4 in 1 bucket?
   / Has anyone tried the Titan 4 in 1 bucket? #11
   / Has anyone tried the Titan 4 in 1 bucket? #12
I think he does not want to mix two different oil types together:confused3:
Oh, yeah, you are probably right. Sorry I missed that. :eek:
What's the oil have to do with it??
Different brands of tractors require different hydraulic oil specifications. The bucket has 2 hyd cylinders that contain oil from whatever tractor you use it on and will dilute whatever tractor you use it on next. Kubota super UDT and SAE15w-140 are not the same, that is the 2 types of oil used in the different tractor hydraulics.
Oh, I see you got your own answer on the oil, I was responding as I went down the list.
   / Has anyone tried the Titan 4 in 1 bucket? #16
Dilution just happens. For example if you put new oil in your tractor, then hook up to an implement you have, you just diluted the product.
   / Has anyone tried the Titan 4 in 1 bucket? #17
Too bad they can't all use the same oil.
I try very hard around here, to NOT mix oils...
Last time I put a loader on that had old oil in it, I ran clean oil through it before hooking up the last hose and I've done it with implements too...
One thing about having gear drive tractors that I have, I can run the same oil in all of them...
SR
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
New/Unused (1) Pallet of Ground Protection Mats (A54865)
New/Unused (1)...
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
2004 Honda Civic Coupe (A55758)
2004 Honda Civic...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
