Can my tractor haul a large rotary cutter?
   / Can my tractor haul a large rotary cutter?
I was worried about my PTO hp also when I bought my rotary cutter last year. I ended up buying a Woods BB600X. I have 35 PTO hp and have used the cutter a lot since buying it. It will eat up pine saplings and brush like they are not there. I probably would of been fine with a BB60X or BB72X also but wanted a heavier duty cutter for the type of work I am doing with it.
That is a very nice rotary cutter! Have you ever had any issues cutting through thick brush?
   / Can my tractor haul a large rotary cutter? #52
It seems most have had better luck with the lighter units than I have. The occasional rock etc. has just beat the light decks to pieces, a TSC unit, even a lighter John Deere. My Bush Hog and Massey Ferguson were much heavier and more reliable for me. I used a 5 foot on a 33 HP tractor and a 6 foot on a 45 tractor. For me the 6 footer would not have been a good fit on the 33 HP. At times even at creeping speeds the brush I occasionally cut is so thick it can stall the tractor. Just giving my experience with over 25 years cutting on my farm.
   / Can my tractor haul a large rotary cutter? #53
If I had a L39.....a med-hd 6' would be on the back. Something in the 1200# range for a 6'cutter.
I ran a bushhog 306 (1100#, 3" cut capacity, 90hp gb) for years behind a 29 PTO HP gear drive l3400.
The l39 will have no issues with weight and heft. And power will be plenty
   / Can my tractor haul a large rotary cutter? #54
I bought it to use on some land I have that has loblolly pines and briars growing in it. I have been running over 6 foot pine saplings, brush and 8 foot briars with it. Cuts it and nothing is left. I run it in low range and take my time in the real thick stuff. This is a picture of the land I have been cutting with it.
   / Can my tractor haul a large rotary cutter? #55
Now there’s a good real world response.
UPDATE
I bought my first rotary cutter!
I appreciate everyones advice and first hand experience. I decided to spend the extra money and pick up a Bush Hog 285. I was blessed enough to find a real nice one on Craigs list.
Time to get to work!
   / Can my tractor haul a large rotary cutter? #57
That is a nice cutter. You did well. I predict you will be as pleased with it's performance as I am with my Brown 472.
   / Can my tractor haul a large rotary cutter? #58
That should do just fine. Great choice.
   / Can my tractor haul a large rotary cutter? #60
UPDATE
Good Pick! It should work well for what you plan to do.
I ran a Brushog SQ172 behind my old L3430 HST (27 PTO HP) with no problems. I just slowed down for the gnarly stuff. The salesman said not to worry about the 30HP minimum.
If I might ask, what did you pay for the 285? I'm thinking of selling my SQ172 and I'd like to get an idea of what it's worth.
Giyi Root Grapple (A53316)
Giyi Root Grapple...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A55787)
2025 GIYI GY-BK56M...
Sky Trak 10054 Legacy 10K Telehandler (A54865)
Sky Trak 10054...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A56129)
2019 FREIGHTLINER...
