Can my tractor haul a large rotary cutter?
   / Can my tractor haul a large rotary cutter?
I was worried about my PTO hp also when I bought my rotary cutter last year. I ended up buying a Woods BB600X. I have 35 PTO hp and have used the cutter a lot since buying it. It will eat up pine saplings and brush like they are not there. I probably would of been fine with a BB60X or BB72X also but wanted a heavier duty cutter for the type of work I am doing with it.
That is a very nice rotary cutter! Have you ever had any issues cutting through thick brush?
   / Can my tractor haul a large rotary cutter? #52
It seems most have had better luck with the lighter units than I have. The occasional rock etc. has just beat the light decks to pieces, a TSC unit, even a lighter John Deere. My Bush Hog and Massey Ferguson were much heavier and more reliable for me. I used a 5 foot on a 33 HP tractor and a 6 foot on a 45 tractor. For me the 6 footer would not have been a good fit on the 33 HP. At times even at creeping speeds the brush I occasionally cut is so thick it can stall the tractor. Just giving my experience with over 25 years cutting on my farm.
   / Can my tractor haul a large rotary cutter? #53
If I had a L39.....a med-hd 6' would be on the back. Something in the 1200# range for a 6'cutter.
I ran a bushhog 306 (1100#, 3" cut capacity, 90hp gb) for years behind a 29 PTO HP gear drive l3400.
The l39 will have no issues with weight and heft. And power will be plenty
   / Can my tractor haul a large rotary cutter? #54
I bought it to use on some land I have that has loblolly pines and briars growing in it. I have been running over 6 foot pine saplings, brush and 8 foot briars with it. Cuts it and nothing is left. I run it in low range and take my time in the real thick stuff. This is a picture of the land I have been cutting with it.
   / Can my tractor haul a large rotary cutter? #55
Now there’s a good real world response.
UPDATE
I bought my first rotary cutter!
I appreciate everyones advice and first hand experience. I decided to spend the extra money and pick up a Bush Hog 285. I was blessed enough to find a real nice one on Craigs list.
Time to get to work!
   / Can my tractor haul a large rotary cutter? #57
That is a nice cutter. You did well. I predict you will be as pleased with it's performance as I am with my Brown 472.
   / Can my tractor haul a large rotary cutter? #58
That should do just fine. Great choice.
   / Can my tractor haul a large rotary cutter? #60
UPDATE
Good Pick! It should work well for what you plan to do.
I ran a Brushog SQ172 behind my old L3430 HST (27 PTO HP) with no problems. I just slowed down for the gnarly stuff. The salesman said not to worry about the 30HP minimum.
If I might ask, what did you pay for the 285? I'm thinking of selling my SQ172 and I'd like to get an idea of what it's worth.
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
5' Skidloader Core (A50775)
5' Skidloader Core...
2013 Ford F-550 4x4 Ext. Cab Service Truck (A55788)
2013 Ford F-550...
2007 Oshkosh S-Series TMMB 11 CuYd Front Discharge Concrete Mixer Truck w/ Tag Axle (A55788)
2007 Oshkosh...
2020 Ford F-350XL (A53314)
2020 Ford F-350XL...
