deserteagle71
Elite Member
- Joined
- Dec 30, 2017
- Messages
- 2,686
- Location
- northern Nevada
- Tractor
- John Deere 2020 diesel, Kubota M7060HDC12
How do you add engine oil to this tractor if the loader is on it???
My first oil change today...only 104 hours since the original owner did the first oil change but that was 14 months ago. I had to work the tractor pretty good for a couple hours so it was nicely warmed up; I parked it on the concrete apron of my garage (won't fit inside with the cab) and raised the FEL all the way to get the arms out of the way. Drained the oil and changed the filter - that all was quick and easy. Then I tried to fill the tractor back up with oil - and found I would need about a 3' long flexible funnel! There is absolutely no way, considering where the oil inlet is located with the upright exhaust and loader support right beside it, to access it any other way unless I used a small funnel and poured the oil in one quart at a time. No room for a bigger jug. I finally ended up grafting a piece of hose onto a funnel and snaking all that down past the exhaust to the oil inlet. Filling it took forever that way - cold diesel oil does not flow very fast!
So I'm interested in knowing what works for others in adding oil to this model tractor? The owner's manual was certainly no help!
