Oil change filters & oil 2538
   / Oil change filters & oil 2538 #1
dwalk19
Gold Member
Addison, ny
2018 LS XG3140H TLB
Hey guys I'm going to do a on oil change on my 2538, what does everyone recommend for oil filters and oil I like to switch over to a full synthetic oil, that should be fine corect, also they don't know how much oil it will use and any filters part numbers, thanks
   / Oil change filters & oil 2538 #2
I get my filters at the dealer its not that much more , And they have them all . Oil at wally world any top brand mobil , shell
   / Oil change filters & oil 2538 #3
Check your operator's manual for weight and quantity. I use full synthetic in all my engines.
   / Oil change filters & oil 2538 #4
you will need to go with 5w40 if you go synthetic iv never herd of anyone doing it around here since not needed but could come in handy up north... I doubt cj5 10w30 would give enough protection
I use delo 5w40 in my 6.7 ford.
You should be able to go on any large dealers website and pull up a quick reference for the filters
   / Oil change filters & oil 2538 #5
I use Rotella 10w-40 oil for diesel engines in 2538, with a Wix oil filter # 51324.
I do not use synthetic, as I change the oil & filter every 100 hours.
Buy the filters on Amazon, and the oil @ TS.
FWIW...
Alright guys thanks, yeah maybe i dont need to use a synthetic oil, I guess it's just habit since I use it in all my vehicles, every 100 hrs for oil and hydraulic oil at 150hrs sound right, I'm at 85 hrs right now
   / Oil change filters & oil 2538 #7
I have the 1538. The engine is every year or 100 hrs and the hydraulic fluid is every 300 on my machine. Dick and I have done a filter list for the 15xx and posted it on TBN. I believe the two models use the same engine.
   / Oil change filters & oil 2538 #8
I ran shell rotella full synthetic 5w-30. It gets cold here.
   / Oil change filters & oil 2538 #9
Most should have a 50 hour break in service for the engine oil
   / Oil change filters & oil 2538 #10
That's a lot of unnecessary oil changing.
UNUSED 20PCS 2in. Polyester Lifting Strap (A50860)
UNUSED 20PCS 2in...
4 BRIDGESTONE 11R24.5 (A50854)
4 BRIDGESTONE...
8 Ton Combo Pintle Hitch (A48081)
8 Ton Combo Pintle...
2013 Acura RDX AWD SUV (A48082)
2013 Acura RDX AWD...
Genie GTH-644 (A50490)
Tandem Axle Rear Truck Frame (A48081)
Tandem Axle Rear...
