JD 6400 stops and starts pulling after it gets hot
   / JD 6400 stops and starts pulling after it gets hot
Talked to JD SERVICE MANAGER and he said the problem seems to be more temperature related since issue only occurs after working hard for over 1.5 hours. However the high Temperature light is not showing on dash??????
   / JD 6400 stops and starts pulling after it gets hot #12
The hour long time is what we've been talking about. The oil is maybe going through a small orifice like a partially opened valve, or your charge pump is worn out or there is a crack in the pumps line.
JD has found a hair line crack in the clutch drum which expands with heat and allows oil to bypass causing a loss of pressure. $5600 to repair😳
   / JD 6400 stops and starts pulling after it gets hot #14
Ouch! I know splitting a tractor involves a lot of labor. My friend payed almost $7000 but he rebuilt everything while it was split.
   / JD 6400 stops and starts pulling after it gets hot #15
Used to be a piece of haywire would fix it. Then a few bucks, then hundreds. Now, hardly anything can be repaired for less then thousands!
I apparently have an air issue in my power quad equipped 6200. Just shows itself in my hyd top link getting air. No other indications. My Menonite independant JD but not JD dealer says they can fix that as if they knew exactly what was wrong. I thought that might be the case with this 6400. I trust these guys to know my tractor light years beyond a real JD dealer!
   / JD 6400 stops and starts pulling after it gets hot #16
And they will fix it for a whole lot less.
   / JD 6400 stops and starts pulling after it gets hot #17
This is an old thread but we are having something similiar happening on our 1993 6400 John Deere. Will work fine for a few hours about 2 then I get lights and tells me to stop. It is the hydraulic overheating light. We changed the filters and all new oil and still doing it.
   / JD 6400 stops and starts pulling after it gets hot #18
What type of transmission do you have? What are you doing with the tractor before the overheat light comes on.
Do you have a loader, power steering?
Often, over heating hydraulic oil results from the oil being forced through a relief valve while trying to protect the system.
The 3 pt hitch is a common culprit. The 3 pt hitch incorporates a feedback rod which tells the internal valve for the 3 pt that the arms have reached the top and to stop sending more oil into a full cylinder.
If you have a feedback rod, it is fastened to the upper lift arm and goes forward to the control valve area of the transmission.
Dave M7040
   / JD 6400 stops and starts pulling after it gets hot #19
I have the quad shift 4 x 4.
Yes has a loader and power steering.
It has done it to us doing different things once when working roads with the blade and another 2 time plowing with the disc harrow.
I will have to do some research on the feedback rod.
   / JD 6400 stops and starts pulling after it gets hot #20
here she is.
UNUSED TOPCAT QUICK ATTACH HYD 4N1 COMBO BUCKET (A51244)
UNUSED TOPCAT...
UNUSED FUTURE QUICK ATTACH PLATE GRABBER (A51244)
UNUSED FUTURE...
2010 International 4400 National Crane 300C Crane Truck (A50323)
2010 International...
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
