Implement Dollies
   / Implement Dollies #1
kclark2227
Kannapolis, NC
Kubota L4701 4WD HST
I am wanting some dollies for my implements to sit on so they can be moved around the building easily. I am also wanting to work on my welding skills so I'll be welding them up. My question is does anyone have a strength chart for box tubing so I know what size tubing to get?
And if anyone has any photos to share that would be awesome also. I am looking to build some for box scrape, carry all, rear blade, FEL bucket and grapple.
   / Implement Dollies #2
I don’t have a strength chart (built all mine with 2x4’s). For shapes a carry all just needs a flat platform with wheels (like a furniture dolly). For my rear blade I used a ‘t’ shape with 3 wheels and blade guides on the top of the ‘T’ to stop the blade from falling off and a vertical section on the base of the ‘T’ to support the attachment point. For pic ideas bxpanded has some good designs. Don’t skimp on the wheels.
   / Implement Dollies #4
I built dollies for all my attachments using 1/8" x1.5x1.5 angle iron. make sure you get beefy enough caster because they roll around better if you do. The heaviest thing was a 850# ballast box and a 750# box blade. They still are a bear to push around.
I wouldn't worry about brakes on them. They are pretty stationary with all the weight on them.
   / Implement Dollies #5
True... I still put one of the four on my wheeled pallets as a brake. Just in case for some unforeseen reason. All four would be needlessly expensive.
   / Implement Dollies #6
Search results for: 'furniture dolly'
You wouldn't be able to buy much steel tubing and casters for the price of these. Could use a pair of them in tandem if weight was a concern.
Harbor freight has a 25% off coupon ending today. (Sunday)
   / Implement Dollies #8
I used 2x4's, 1/2" plywood, and screws to make the proper sized rectangles for each implement. HD has some nice 3" steel wheels that I screwed into the bottom for about $5 each and I can roll all my implements around my shop (concrete floor). I also bought a 2 car mover dollies from HF and attached a 2x4 across them to make a dolly for my tiller. They all work great, but will only work on concrete or asphalt.
   / Implement Dollies #9
These are a little different might spark an idea. They slide into the square tubing frame on my chipper.
gg
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2018 Ford F-350 Crew Cab Service Truck (A56858)
2018 Ford F-350...
Mini-Excavator Forks (New/Unused) (A59225)
Mini-Excavator...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
116 Gallon Poly Fuel Tank W/12V Pump (New/Unused) (A59225)
116 Gallon Poly...
PumpJack Brand Pump Jack (A56435)
PumpJack Brand...
