Trap camera placement
   / Trap camera placement #1
JFoy
Clemmons/Lexington, NC
Kubota BX25D
The wife and I have been using trap cameras to see various wildlife around the property lately. I have two spots I've been watching. The first is my patio and the feral cats that come eat our scraps. I set the camera on the patio floor which puts it in the same horizontal plane as the feeding bowl. It's about 5 ft. back from the bowl. We get excellent shots of all the kitties at night.
The second location is the backyard. I have an old dog bowl back there where we put the bigger things like ham bones. The camera is placed on a pallet which is roughly in the same horizontal plane about about 10ft back. Twice now, something eats the ham bone but nothing shows up on the trap cam. I know the distance shouldn't be an issue as we hung them in trees in a field and get shots of animals 30ft away easily.
What do you guys find is the best angle and distance for your trap cams?
JFoy
   / Trap camera placement #2
I use 4 game cams and the angle I found head high 20+ feel away slight tip downwards.
Does your camera flash or red sensor light come on if so might be and issue,critters a lot smarter than we give the credit for.
   / Trap camera placement #3
...In North Carolina and across the United States, the domestic animal that is most commonly infected with rabies is the cat. Cats that are kept outside unsupervised may prey on wildlife that are infected with rabies.
Depending on local laws feeding feral cats can find you both legally and financially responsible...
Feral cats are the scourge of native wildlife...they should be humanely euthanized...
NC DPH: Rabies Control in North Carolina
   / Trap camera placement #4
I had a hole under my porch in a weekend place we had. The house was in a rural location and there was lots of wildlife around, so we were not sure what might be living under the porch... I set up my game cam and got about a hundred photos of sunlight heating the side of the place and wind moving a branch. That combo would set off the camera. I never got a picture of the critter. One day we saw a gopher tortoise right outside of the hole and the mystery was solved!
It seems like you may have a problem with the sensor on that camera. I'd check it for some trash stuck to the lens first. You never know, though, maybe bigfoot is cold blooded!
   / Trap camera placement #5
Cats really are hard on the wildlife.
We put a game cam in our garden at the end of the gardening season. Mounted low on the fence, about 4 inches above ground. We had opened up the gates so anything could get in and out. Pretty cools shots, i might try it again, if i get that camera back from nephew.
Thanks for the comment. I'll change mine approach and see what happens.
Cats really are hard on the wildlife. We put a game cam in our garden at the end of the gardening season.
We have a 3 acre spot that we have been cleaning up now for over a year. Lots of deer, turkeys, etc. It has been a lot of fun to see what walks through the area at night. Even got to watch two fawns mature throughout the year.
   / Trap camera placement #8
Mine are mounted a little over waste high and I set them from flat to slightly downward. The infrared lights have a constant glow after dark. The deer often walk up and look into the cameras. I guess they are intrigued by the dim glow of the lights or just curious about the whole setup.
2021 CATERPILLAR 299D3 XE SKID STEER (A60429)
2021 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CASE IH MAXXUM 115 TRACTOR (A60430)
CASE IH MAXXUM 115...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2015 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2015 FREIGHTLINER...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
