Dftodd
Super Star Member
- Joined
- Oct 19, 2014
- Messages
- 10,427
- Location
- vilonia, arkansas
- Tractor
- Massey Ferguson 1825E, Kubota Z121S
In the extreme it can matter. For lighter tow vehicles if you put too much tongue weight on a tag trailer the front end of the tow vehicle can get light and have similar tail-wagging effects as too little tongue weight. In general though I'm totally with you on erring on the side of extra tongue weight.
As a side note on bad towing:
I helped a guy push his fairly large (for MN lakes) 18-20' boat into a storage unit last fall. It was on a tandem axle trailer. When he popped the hitch release lever the tongue actually popped up off the ball, there was negative tongue weight. It was an ancient F150 that was probably at the very upper end of towing capacity with that boat anyway. I have no idea how he managed to drive it like that without having an accident.
Rob
I've had some equipment that was tandom axle. You could lower the Jack completely then remove it from the equipment. Tongue would float about 2ft off the ground. If the equipment was parked on a knoll, you sometimes had to stand on the tongue to get it to drop down low enough so you could latch it.
Equipment weighed 10,000lbs. Needless to say, with the tongue weight so light, the equipment so heavy, we do not pull it with anything smaller then a 1 1/2 ton chassis (F550 or larger). Which at work means it gets hauled with my F550 service truck that weighs 15,000lbs or the 20 ton roll back.
