no hydraulics can be added ????? ... the end of my dream ??
   / no hydraulics can be added ????? ... the end of my dream ??
Hi Everybody
Last year I posted on here because I wanted to add hydraulics to my Chinese tractor. Local hydraulics "specialists" laughed at me because of my Chinese garbage and said I had been fooled.
So I got curious and ended up here.
My story is still out here but I do want to end it in beauty !!!
I got lots of nice and friendly reactions out here but I have to admit that most of it was like Chinese to me as I knew literaly nothing about hydraulics or tractors for that matter. Yeah, why by a tractor if you are a geek like me ?! Well, I started with a shovel but got blisters and way to tired hahaha
Anyway, There was one person out here who proposed to help personally. Dave, I can not thank you enough for having been my superhero out here !!!!!!! During several months Dave patiently listened, did research for me, contacted professionals etc etc. Nothing seemed to much for him to help me understand the basics of things and guide me from the most simple things to the more complicated stuff ....
I have the biggest esteem for a man who understands how to place himself in the shoes of an ignorant and stay patient and friendly and understanding !!!
This may sound exagerated to you people but to me he is THE example of the best neighbour one can ever dream to have !!!
   / no hydraulics can be added ????? ... the end of my dream ?? #32
The real question is did you end up with hydraulics and how did you do it? That way the answer will be out here with the story.
   / no hydraulics can be added ????? ... the end of my dream ?? #33
That's awesome to hear!
Are you making progress with adding the hydraulics?
   / no hydraulics can be added ????? ... the end of my dream ?? #34
I greatly appreciate the thanks from Marcel.
He now has two rear remotes controlled by a valve block similar to one for a FEL.
The 3 pt hitch is fed from a high pressure carry over sleeve in the FEL valve body.
Just finding where the HPCO sleeve was installed (all internal to the FEL valve) took tech support on several continents.
The Chinese labels on everything was a big problem and needed translation. A priority valve and a hydraulic pump look identical.
Google does not have a Chinese translation service I could find.
The manual he was given was for a different tractor series.
Working with Marcel was great. He would be getting advice from so called hydraulic tech's in France and England but would return to follow the path I set out for him.
He now has a safe installation working the way he wants.
It is kind of scary to find experts saying: "just use the tank port to feed another circuit" Further, the specification pressure limitations of the valve's tank port mean nothing to these experts.
Dave M7040
   / no hydraulics can be added ????? ... the end of my dream ?? #35
I don稚 see where the complication is . Tie the open Center valve block for the SCV in series with the supply line to the loader control valves .
   / no hydraulics can be added ????? ... the end of my dream ?? #36
He now has two rear remotes controlled by a valve block similar to one for a FEL... (and) a safe installation working the way he wants.
Great job Dave!
   / no hydraulics can be added ????? ... the end of my dream ?? #37
Lets start with the fact that there was NO valve block and go from there.
There were no SCV's nor FEL
Send me your email and I will forward my 100+ emails to you so you can dig further and advise the next buyer of a Chinese tractor on how to reach a solution when the owner has zero knowledge.
Dave M7040
   / no hydraulics can be added ????? ... the end of my dream ?? #38
Dave M7040
Nice, So glad there are good folks helping other good folks.
   / no hydraulics can be added ????? ... the end of my dream ?? #39
Pics?
   / no hydraulics can be added ????? ... the end of my dream ?? #40
The tractor sitting in France
Here is the power steering filter and Chinese instructions which I had translated:
Clean after using 200 hours.(in gasoline, use soft brush to clean the dirt).
Please change if any damage.
Xinxiang city Tainuo auto part factory
Other Chinese labels needing translation
Currently only one set of rear remotes is being used but a second is available
A confusing situation. Order a power beyond sleeve and invoice calls it a Grub screw.
Part number is this part
The hydraulic reservoir is not the transmission but a sealed container under the lift arm and piston.
Forum limits number of photos so story ends
Dave M7040
2017 Nissan Titan (A55788)
2017 Nissan Titan...
Lockwood 480 Pecan Harvester (A55315)
Lockwood 480 Pecan...
2013 Ford Edge Limited AWD SUV (A55853)
2013 Ford Edge...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2018 KENWORTH T270 SERVICE TRUCK (A57192)
2018 KENWORTH T270...
