Just make sure you know your road can accept delivery of your new tractor
   / Just make sure you know your road can accept delivery of your new tractor #51
If the driver of the lowboy had time to remove the tractor from the lowboy, he could just use it to push the trailer on across the tracks. With reduced weight on the trailer it just might be easy enough to just push it over the hump. Usually there is not enough time for all of this to happen, which is why it happens.
David from jax
   / Just make sure you know your road can accept delivery of your new tractor #52
David from jax
The way that the tractor blew off the trailer like it wasn't chained down, they may have tried to do just that.
   / Just make sure you know your road can accept delivery of your new tractor #53
That should buff out !
   / Just make sure you know your road can accept delivery of your new tractor #55
David from jax
I had also wondered if they attempted to unload either tractor, looked like they could have driven the pair of them off the side with no damage. I agree with then using one tractor to pull the truck clear.
   / Just make sure you know your road can accept delivery of your new tractor #56
Getting unstuck:
Not just low trucks:
Bruce
   / Just make sure you know your road can accept delivery of your new tractor #57
I have never, ever seen that low clearance signage. It does open a whole new can of worms. If a truck has made it over 99 such crossings and the 100th is a little different, and an accident occurs, who is responsible. With a bridge, the clearance is more or less understandable.
I have seen many.
   / Just make sure you know your road can accept delivery of your new tractor #58
Or the driver could have called a tow truck and had the tractor/trailer removed from the crossing before the train got there.
   / Just make sure you know your road can accept delivery of your new tractor #60
Funny all the could've would've, should've comments. I haven't seen anything that indicates the truck was stuck for very long before the train showed up.
2021 Deere 333G (A53317)
2021 Deere 333G...
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
9000 (A47477)
9000 (A47477)
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2018 Ford Fusion SE Hybrid Sedan (A56859)
2018 Ford Fusion...
