135 Locked up on startup!
   / 135 Locked up on startup! #1
rkelman
BELLEVILLE
Massey Ferguson 135
Ok i have a 135 Diesel that just barely started then stopped abruptly. I pulled the starter and i can turn it over about 1/8th of a turn then it stops and i can go back the other way 1/8. I pulled the valve cover first and saw nothing awry. I then pulled the head. Still nothing. I pulled the sump and still nothing. No metal in the bottom either. Any ideas where to go next? I appreciate any advice I can get. Oh the alternator / fan turn freely as well.
   / 135 Locked up on startup! #2
:welcome:
To the TBN forum. Glad that you joined but sorry to hear that you are having trouble.
Is anything attached to the PTO? Can you turn the PTO?
Was the clutch done ? Lockingplates reinstalled ?
Ok no clutch work done and nothing hooked to the pto and it turns freely with my hand. I had my wife push the clutch down and with it down i can turn the engine over.
   / 135 Locked up on startup! #5
Mf 135.....dualclutch....did she push it down all the way or only the disengage the gearbox ?
Mybe the gearbox gears is lockeg in 2 gears ?
   / 135 Locked up on startup! #8
Can you turn the engine with the clutch down? You haven't the classic MF fun of getting it in to two gears at once?
   / 135 Locked up on startup! #9
Ok ! When opening the gearboxfillerhole there should be a squer lockbolt right in the middle of that hole . If not .....lever it just a little to get it in the middle. If it is in the middle....look down into the hole...you will see a big gear on the clutchside to the front...shift that gear to the middle of it's travel to get neutral.
Ok Which one is the gearbox filler hole? I just tried again and as soon as you feel some resistance in the clutch i can turn the engine over. In the top 1/3rd of travel i'd say. That and the fact that i was able to roll the tractor with my trucks help tells me its not stuck in a gear. I think?
2023 RTVXG-850 SideKick (A57024)
2023 RTVXG-850...
2006 International 4300 S/A Day Cab Truck Tractor (A55852)
2006 International...
UNUSED FUTURE DEER SHAPED SHOOTING TARGET (A57193)
UNUSED FUTURE DEER...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A57024)
2023 Unverferth...
2023 Deere 17G (A53317)
2023 Deere 17G...
AGT SAII100 SKID STEER QUICK ATTACH 48" (A57193)
AGT SAII100 SKID...
