leonz
Super Member
No the Jet pump will pump from the creek to the water tower.
A two inch transfer pump will only push water at a high volume under low pressure with resistance so far and a fire pump and the hose need for a fire pump will run him almost 4 figures at least not including sales tax.
Between the pump wire the jet pump and the 500 foot of poly pipe and fittings he may be looking at $1100.00.
A mud pump/diaphram pump will will work but he will need an air compressor and hose and the mud pump depending
on the brand will be very expensive.Saying that a Gorman Rupp SandPiper pump will work BUT the smaller ones will not pump very long distances and elevations where a 2 pipe jet pump or submersible will work much better.
If he has a 110 volt generator great, he can hook up a direct burial cable to either pump and have all the water he needs without a 2 wire power cable and a switch.
