3-Point Hitch Case-IH 895 three point hitch only lifts half way
   / Case-IH 895 three point hitch only lifts half way #1
high road
case ih 895
Hello, new member here. I bought a Case-IH 895 used with 4000 hours. All other hydraulic functions are normal. Lift arms only raise half way. Rate of lift is normal. Capacity of lift is normal. Any help appreciated. Thanks.
   / Case-IH 895 three point hitch only lifts half way #2
:welcome:
To the forum High Road. We are glad that you joined.
For the position control lever to work normally, the draft lever must be all the way forward/down. Hope this helps.
   / Case-IH 895 three point hitch only lifts half way #3
Check hydraulic oil level first, if you have not already.
thanks...i will take a closer look tomorrow morning...maybe it is just cockpit error...
oil level is good ... will be back at it tomorrow morning...thanks
New 40ft High Cube 6 Door Container (A59000)
New 40ft High Cube...
Case Skid Steer Backhoe Attachment, S/N 391998, 20" General Purpose Bucket, Asset# 71 (A59076)
Case Skid Steer...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
VACUUM PLANTER PLATES (A52708)
VACUUM PLANTER...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56435)
2022 Schulte...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
