3-Point Hitch Case-IH 895 three point hitch only lifts half way
   / Case-IH 895 three point hitch only lifts half way #1
high road
case ih 895
Hello, new member here. I bought a Case-IH 895 used with 4000 hours. All other hydraulic functions are normal. Lift arms only raise half way. Rate of lift is normal. Capacity of lift is normal. Any help appreciated. Thanks.
   / Case-IH 895 three point hitch only lifts half way #2
:welcome:
To the forum High Road. We are glad that you joined.
For the position control lever to work normally, the draft lever must be all the way forward/down. Hope this helps.
   / Case-IH 895 three point hitch only lifts half way #3
Check hydraulic oil level first, if you have not already.
thanks...i will take a closer look tomorrow morning...maybe it is just cockpit error...
oil level is good ... will be back at it tomorrow morning...thanks
2005 CATERPILLAR 262B SKID STEER (A52709)
2005 CATERPILLAR...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2013 CATERPILLAR 259B3 SKID STEER (A52709)
2013 CATERPILLAR...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2016 Nissan Pathfinder SUV (A56859)
2016 Nissan...
SKID STEER ATTACHMENT MAINTAINER BLADE (A58214)
SKID STEER...
