3-Point Hitch Case-IH 895 three point hitch only lifts half way
   / Case-IH 895 three point hitch only lifts half way #1
high road
case ih 895
Hello, new member here. I bought a Case-IH 895 used with 4000 hours. All other hydraulic functions are normal. Lift arms only raise half way. Rate of lift is normal. Capacity of lift is normal. Any help appreciated. Thanks.
   / Case-IH 895 three point hitch only lifts half way #2
:welcome:
To the forum High Road. We are glad that you joined.
For the position control lever to work normally, the draft lever must be all the way forward/down. Hope this helps.
   / Case-IH 895 three point hitch only lifts half way #3
Check hydraulic oil level first, if you have not already.
thanks...i will take a closer look tomorrow morning...maybe it is just cockpit error...
oil level is good ... will be back at it tomorrow morning...thanks
2016 Ford F-150 Single Cab Pickup Truck (A55973)
2016 Ford F-150...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2004 JOHNSTON STREET SWEEPER (A58017)
2004 JOHNSTON...
2021 CAT SKID STEER (A55973)
2021 CAT SKID...
2019 CATERPILLAR 226D SKID STEER (A52709)
2019 CATERPILLAR...
2010 KENWORTH T660 TANDEM AXLE MID ROOF SLEEPER (A58017)
2010 KENWORTH T660...
