Color Coding on GC Loader Valve
   / Color Coding on GC Loader Valve #1
dnw64
Southeastern Vermont
Kubota B3030 Cab
I had a small leak in my valve so I took out the fittings and replaces the O-Rings, and forgot to note which one went where...
Of course it doesn't really matter which one goes where, but if the color coding from the zip ties is going to be helpful, it does make a difference.
Someone have a pic of their valve?
   / Color Coding on GC Loader Valve #2
Here's the way it is on my 2310, but keep in mind there have been some discrepancies in the colors occasionally from the dealer or factory....
This is standing in front of the tractor looking rearward.
   / Color Coding on GC Loader Valve #4
I don't think there is a "factory" colour code for the hoses. My GC2300 is a bit different.Nimco valve block.JPG
The ports I posted are not the actual correct ones, just the closest to the couplings, so I deleted them, to avoid confusion.
The spool on the left side controls the lift arms, the spool on the right the curl function.
Direction can be changed by switching the connections curl rod/base, or the lift rod/base
Hmmm. Ok. I guess I will just have to try it and see what happens :D
Problem is that I don't have anything attached right now so I won't know until I go to use it, and probably won't remember that it may be hooked up wrong!
:laughing:
   / Color Coding on GC Loader Valve #6
Hi DNW,
I am on shift today, tomorrow when I get home I can take a picture of my connections for you if you still need reference. I have a 2017 gc1710. I"ll just have to figure out how to post a pic up.
That's probably the most helpful :thumbsup:
   / Color Coding on GC Loader Valve #8
the manual has a pi ture and description of each of the couplers.
   / Color Coding on GC Loader Valve #10
Mind helping a new guy? I also have a slight leak. Is there anything else inside the valve I can lose besides the O-ring?
I had copied this from another poster:
Tilt cyl rod: Red
Tilt cyl base: Blue
Lift cyl base: Green
Lift cyl rod: Yellow
-Phil
1996 Stoughton Semi-Van Trailer (A50860)
1996 Stoughton...
2025 25ft. 800Amp Extra HD Booster Cables (A48081)
2025 25ft. 800Amp...
2015 Ford F-250 Knapheide Service Truck (A48081)
2015 Ford F-250...
2015 Chevrolet Impala Sedan (A49461)
2015 Chevrolet...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2016 Hyundai Equus Sedan (A48082)
2016 Hyundai Equus...
